Thread Number: 75227  /  Tag: Vintage Automatic Washers
Filterflo suspension
Post# 990484   4/12/2018 at 20:53 (2,176 days old) by potatochips ( )
I'm in the middle of restoring a filter flo machine while using a donor. One machine I have had a transmission leak which has made its way down to the suspension as you can see in picture one. The donor machine has dry snubber pads etc. How stiff should the FF suspension be? And when should the snubber pads be replaced along with the rubber yoke pads and yokes?
Post# 990510 , Reply# 1   4/13/2018 at 06:00 (2,176 days old) by combo52 (50 Year Repair Tech Beltsville,Md)
When Needed
combo52's profile picture
Normally you can clean the pads [ use brake cleaner ]they are meant to be dry, you replace the rubber mounts if they are badly cracked hard or otherwise deteriorated.
John L.
Post# 990520 , Reply# 2   4/13/2018 at 06:38 (2,176 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)
John has it right this time
jetcone's profile picture
Those pads and mounts last pretty long, my 1956 still has its original ones and it damps just fine. They should drag across the steel plate not grip. They shouldn’t slide across which I can see in th first picture must have been happening with all that oil. I also use mineral spirits or better yet laquer thinner as that evaporates completely from the pads.
Post# 990541 , Reply# 3   4/13/2018 at 08:16 (2,176 days old) by potatochips ( )
Thanks Jon and John! On the machine with the transmission leak they slide nicely across and its quiet. The second one they drag a bit but Ill get them cleaned up and back to spec.
Post# 990720 , Reply# 4   4/14/2018 at 16:55 (2,174 days old) by Dustin92 (Jackson, MI)
If I remember correctly, (it's been years since we had our Filterflo), ours had very stiff/firm suspension.
