Thread Number: 75227
Filterflo suspension |
Post# 990510 , Reply# 1   4/13/2018 at 06:00 (2,198 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 990520 , Reply# 2   4/13/2018 at 06:38 (2,198 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Those pads and mounts last pretty long, my 1956 still has its original ones and it damps just fine. They should drag across the steel plate not grip. They shouldn’t slide across which I can see in th first picture must have been happening with all that oil. I also use mineral spirits or better yet laquer thinner as that evaporates completely from the pads.
Post# 990541 , Reply# 3   4/13/2018 at 08:16 (2,197 days old) by potatochips ( )   |   | |
Thanks Jon and John! On the machine with the transmission leak they slide nicely across and its quiet. The second one they drag a bit but Ill get them cleaned up and back to spec. |
