Thread Number: 75235
/ Tag: Refrigerators
What is the optimal freon level for vintage refrigerator GE LW 11P? |
Post# 990772 , Reply# 1   4/15/2018 at 01:52 (2,202 days old) by Stan (Napa CA)   |   | |
Post# 990773 , Reply# 2   4/15/2018 at 02:08 (2,202 days old) by Stan (Napa CA)   |   | |
Post# 990808 , Reply# 4   4/15/2018 at 10:40 (2,202 days old) by Lorainfurniture (Cleveland )   |   | |
That kind of looks like a rotary compressor. I’m not sure what the psi reading will be. Just charge slowly until you have a full frost pattern, and no frost on the low side line in the machine compartment. |
Post# 990848 , Reply# 5   4/15/2018 at 15:30 (2,202 days old) by vintage-stuff (Long Beach, CA)   |   | |
Thank you so much for your advice! I will check if there is a tag or info on the compressor before I refill. Thanks again, Greg |
Post# 990851 , Reply# 6   4/15/2018 at 15:41 (2,202 days old) by RP2813 (Sannazay)   |   | |
Post# 990887 , Reply# 7   4/15/2018 at 20:15 (2,201 days old) by funktionalart (Rison, AR)   |   | |
Keep in mind that my GE is a 1960 upright model, and circa 13 cu. ft....which is somewhat larger than the wall hung units. Mine takes a max of 3 lb. worth of R12:
Post# 990889 , Reply# 8   4/15/2018 at 20:17 (2,201 days old) by funktionalart (Rison, AR)   |   | |
Post# 991315 , Reply# 10   4/18/2018 at 20:14 (2,198 days old) by Lorainfurniture (Cleveland )   |   | |
Your gauges can only read pressure. To charge 3# of r12, you first have to vacuum the system completely (with a 2 stage vacuum pump), then charge the system by weighing it in. |
Post# 991326 , Reply# 11   4/18/2018 at 21:53 (2,198 days old) by speedqueen (Metro-Detroit)   |   | |
Post# 991338 , Reply# 12   4/18/2018 at 22:33 (2,198 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Wow, I am not sure where to start, the posts above are either mostly or completely wrong.
It is best to use R-12 if possible in these older refs.
The only correct way to charge this ref is to measure the refrigerant in, Gauges are never used for charging a residential refrigerator.
On these GEs the correct charge weight in in the service manual, NOT on the model # tag, this ref does not require anywhere near 3 pounds of R-12, probably somewhere between 7 and 12 oz.
This is a piston compressor with a low side shell.
You should remove the leaky clamp-on charging port someone put on this ref. Then either use the GE charging tool with the built-in charging port or if the charging tool is not available braze on a proper charging port.
Then you need to pull a proper vacuum and see if it holds a vacuum, it is also ideal to replace the filter dryer.
If it holds a vacuum, then charge by weight and you should be in business.
Post# 991359 , Reply# 13   4/19/2018 at 04:52 (2,198 days old) by potatochips ( )   |   | |
Paul or turquoisedude has one of these too, I wonder if he has any model specific information on this!? |
Post# 991362 , Reply# 14   4/19/2018 at 05:55 (2,198 days old) by turquoisedude (.)   |   | |
