Picked up a Hitachi PS-128p twin tub and she is leaking from the washing tub. Found an exploded view on line and probably just a washer or bushing. Was wondering if anyone has a manual or even better a service manual for this unit.
Many thanks in advance.
Post# 991220 , Reply# 1   4/18/2018 at 08:33 (2,198 days old) by gizmo(Victoria, Australia)
The site I have linked to below is in Australia, but it gives an exploded diagram of the parts so it should help you understand what is under the hood.
I would first suspect the pump and hoses as a source of leak. Perhaps you could remove the back panel, then fill the tub and look in the back to see where the water is leaking.
If it is leaking over the gear case, then it is just an o-ring, you could just take the old one to any bearing supplier and ask them to match the sample.
