Thread Number: 75346  /  Tag: Modern Automatic Washers
Miele W1918 Novotronic drum NOT ROUND
scroll >>> for more items
Post# 991860   4/23/2018 at 09:43 by al7405 (Toronto)
I have a W1918 Novotronic (16yr) with ~6400 cycles- Have replaced an inlet valve 3 yrs ago, and, this week a door seal. The door seal has abraided away due to the Inner basket drum coming out of 'round' (10mm).
No clue how this happened after all this time...
This deformation allowed the drum to hit the door seal and 'burn through' the seal, at high RPM-(1200-1600)
Has any tech on these boards seen this happen? I was able to bring the basket opening back into (close to round 3mm off) by using an expansion clamp and exerting pressure on the lip.
Thanks in advance,
Al
Post# 991871 , Reply# 1   4/23/2018 at 11:23 by Rolls_rapide (Scotland, UK)
rolls_rapide's profile picture
I vaguely think I read somewhere, of someone with an elderly Bosch machine, where there was a similar occurrence. The 'spider' attached to the rear of the inner drum had fractured one or more of its three 'legs'.
Post# 992032 , Reply# 2   4/24/2018 at 23:49 by richnz (New Zealand)
From berlin-repariert.de
Fantastic blog.
If you use Chrome it can translate from German.
An excellent site. Lots of putrid, clogged driers and quite amazing repairs.
www.berlin-repariert.de/miele-was...
Post# 992044 , Reply# 3   4/25/2018 at 05:45 by arbilab (Ft Worth TX (Ridglea))
See above re: spider.  I wouldn't stand in the room while it was going ~1400.  We saw last week what 1/22nd imbalance does to a turbine at 10,000RPM.  Yes, 7 times faster; also 8000 times as expensive.  Just some perspective.
You've got one cracked arm and a lot of flex stress on the remaining 2.  If another cracks the load on the last one exceeds its strength and kerblooie.  You won't get sucked out the window, but worst case you could have a hole in your wall.
Post# 992095 , Reply# 4   4/25/2018 at 14:44 by Launderess (Quiet Please, There´s a Lady on Stage)
That wash container is heavy stainless steel
launderess's profile picture
Thus highly doubt it has become deformed; would take whacking at it with a mallet or something of similar force to do that I should think.
Likely something is broken/wrong with some part of the suspension system (springs and or shock absorbers). This and or as suggested perhaps one of the spiders on rear of outer tub have become damaged.
Whatever the reason the wash tub is rising up out of alignment which is the cause of your woes.
You can either take off lid and or open front of machine to have a peek, or call out Miele for a service call.
Usual cause of out of alignment wash container with Miele is that one or both of the shocks have gone. They are what control movements of tub and when that is weak or missing it often manifests it self in damage you've seen. That is scratches or other marks on glass port hole.
Post# 992099 , Reply# 5   4/25/2018 at 15:01 by Rolls_rapide (Scotland, UK)
@ Launderess:
No, not the cast iron frame of the outer tub.
It is very probably the spider attached to the inner drum... the same type of problem which affects the Samsung frontloaders, i.e. crumbling spider.
