Thread Number: 75398
/ Tag: Detergents and Additives
Will the recipe for this home brew version of "Shout" work? |
Post# 992389   4/28/2018 at 15:23 (2,161 days old) by scoots (Chattanooga TN)   |   | |
Post# 992414 , Reply# 1   4/28/2018 at 20:01 (2,161 days old) by Supersuds (Knoxville, Tenn.)   |   | |
I think you know the answer!
The ingredients are pretty different. they both have water and fragrance. Shout® Formula 35*4054 Ingredients Water Ethoxylated Alcohol: Cleaning Agent Citric Acid: Builder Sodium Hydroxide: Builder Sodium Borate: Builder Acrylic Copolymer: Thickener Polyacrylate Polymer: Cleaning Agent Benzisothiazolinone: Preservative Subtilisin: Enzyme Dodecanol: Stabilizer Fragrance Downy Dilutes April Fresh Water: Process aid Diethyl ester dimethyl ammonium chloride: Softening agent Fragrance Calcium Chloride: Process aid Formic acid: Hydrochloric acid Dye: colorant Formic acid: pH modifier hydroclhloric acid: pH modifier Polydimethylsiloxane: Process aid Methylisothiazolinone/ Methylchloroisothiazolinone: Preservative Cationic polymer: Structuring agent Diethylenetriamine pentaacetate,sodium salt: Chelator |
Post# 992439 , Reply# 2   4/29/2018 at 00:17 (2,161 days old) by Tomturbomatic (Beltsville, MD)   |   | |
The most effective pretreating formula was in the metal aerosol cans and the formula contained dry cleaning fluid. |
Post# 992483 , Reply# 3   4/29/2018 at 11:40 (2,160 days old) by scoots (Chattanooga TN)   |   | |
I almost regret posting such an obvious question now, but the person who made the recommendation is a very good friend and she went as far as to buy a bottle of Downy for me ... so you see I'm going to get a follow up "How did it work?" question and I have to give a careful reply.
Thanks for the info list: I hope you didn't have to type that all out. Was particularly interested to see that there was an enzyme component to Shout. It was my understanding from earlier posts here that pre-sprays like Shout is where the enzyme additives back in the 70's all went. |
Post# 992485 , Reply# 4   4/29/2018 at 11:51 (2,160 days old) by scoots (Chattanooga TN)   |   | |
Post# 992502 , Reply# 5   4/29/2018 at 14:41 (2,160 days old) by Supersuds (Knoxville, Tenn.)   |   | |
I mostly copied and pasted it, but had to tweak the formatting. No biggie!
There is still an aerosol Shout that works very well on oily stains, but it will damage or even take the finish off a washer or dryer if you overspray, so I tend to use it sparingly. I believe that dry cleaning fluids like Stoddard solvent are forbidden in any application now. Launderess or Stan or Tom Turbo will know, among others. Not sure how you should break the news to your friend... |
