Thread Number: 75496
Baking Soda on sofa |
Post# 993331 , Reply# 2   5/6/2018 at 19:41 (2,153 days old) by RP2813 (Sannazay)   |   | |
Sounds like the same procedure as the various "Carpet Fresh" types of products recommend.
There's also the "Febreze" option. With loose cushions you could maybe spray them with that and then send through the dryer (assuming it would cause no ill effects on the dryer). Otherwise, the damp towel method sounds like a good plan, but if you plan to use low heat, I'd lean towards damp as opposed to wet, and make sure the dryer sheets will activate on the low heat setting. |
Post# 993365 , Reply# 3   5/7/2018 at 05:28 (2,153 days old) by askolover (South of Nash Vegas, TN)   |   | |
Post# 993376 , Reply# 5   5/7/2018 at 07:25 (2,152 days old) by askolover (South of Nash Vegas, TN)   |   | |
