Thread Number: 75550
Maytag A211 replaced with A210 a few questions please |
Post# 993854 , Reply# 2   5/11/2018 at 06:35 (2,170 days old) by Cartel (Chilliwack BC)   |   | |
Thanks for the reply. I was thinking this? CLICK HERE TO GO TO Cartel's LINK |
Post# 993878 , Reply# 3   5/11/2018 at 13:51 (2,170 days old) by potatochips ( )   |   | |
Im not sure what that part is, or where it belongs to. Its not listed on the A210 or 211 in any of the parts breakdown sheets near the agitator. I have two Maytags that have some vertical play, Im not worried about it. |
Post# 993892 , Reply# 4   5/11/2018 at 16:29 (2,170 days old) by DADoES (TX, U.S. of A.)   |   | |
The part of question is a Maytag agitator stop ring. I have three spares. It fits onto the drive shaft and anchors agitators that press on instead of having a set-screw.
Post# 993893 , Reply# 5   5/11/2018 at 16:37 (2,170 days old) by potatochips ( )   |   | |
Learn something new every day! I do see it on the breakdown for the 806. I had no idea they has a rubber stop ring, I always thought it was friction fit just by the plastic. |
Post# 994068 , Reply# 7   5/13/2018 at 12:26 (2,168 days old) by potatochips ( )   |   | |
The belts naturally slip on a Maytag when its draining and spinning. Once the water is out of the tub the slip will become less and less. |
Post# 1178675 , Reply# 9   4/20/2023 at 22:53 (365 days old) by Cartel (Chilliwack BC)   |   | |
sorry they are both 3 hole agitator |
Post# 1178684 , Reply# 10   4/21/2023 at 04:07 (364 days old) by qsd-dan (West)   |   | |
I am smelling something getting hot like charred circuit board or motor windings. A bit of a sweet smell coming from the back.
Does the smell come from high up like the console or lower down? In the top rear of the machine, there's the console where the timer and switches are housed. Down a bit and to the left is where the water valve is located. You can remove the front panel and run the machine through the entire cycle to sniff around the motor, just be aware of the spinning transmission during the spin cycle if you have kids or animals. Thankfully, there's no circuit board in these machines to fry! |
