Thread Number: 75561
/ Tag: Ranges, Stoves, Ovens
GE trim rings and burner bowls |
Post# 993859   5/11/2018 at 08:42 (2,175 days old) by luxflairguy (Wilmington NC)   |   | |
My new apartment has a 1984 GE Spacemaker 20" stove. I can't find GE made rings an bowls that work with the lift-up burners. Are they still available? thanks! Greg |
Post# 993860 , Reply# 1   5/11/2018 at 08:46 (2,175 days old) by Steved (Guilderland, New York)   |   | |
Found these on Target.com. Less than $20 for the set
Post# 993861 , Reply# 2   5/11/2018 at 08:54 (2,175 days old) by panthera (Rocky Mountains)   |   | |
I clean a lot of GE/Hotpoint ranges from the 1960s through this century and there's some real problems with bad contact/loose wires in these after a few decades. You might want to unplug the stove and check the plug in receptacles or the screw on porcelain burner covers.
The trim rings can't go in the self cleaning oven, the porcelain drip bowls can. |
Post# 993862 , Reply# 3   5/11/2018 at 08:57 (2,175 days old) by ken (NYS)   |   | |
