Thread Number: 75578
Wash-in Line-up..and extending a gas line |
Post# 994073   5/13/2018 at 12:41 (2,167 days old) by moparwash (Pittsburgh,PA )   |   | |
Thanks to Airsled, the lineup is in place. Question: Can a gas line be safely extended using 2 of these hookups back to back just for the wash-in?..(don't want to blow up the house!)
Post# 994082 , Reply# 2   5/13/2018 at 14:32 (2,167 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)   |   | |
Not "just" for the wahs in. |
Post# 994085 , Reply# 3   5/13/2018 at 15:42 (2,167 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
I always just used an old garden hose when we tested dryers and ranges, did this for over 20 years.
However I can't recommend this, you can temporally use two flex connectors but it is not code to do so.
We bought a bunch of outdoor gas grill connectors that are around 10 feet long, these have a nice quick-connect coupler that has a shut off valve in it so the gas flow stops when it is disconnected, the only problem with the grill connectors is that they are intended for outdoor use only.
Post# 994093 , Reply# 4   5/13/2018 at 16:58 (2,167 days old) by Yogitunes (New Jersey)   |   | |
I would need to see your setup behind the machines.....but why not just tap into the existing gas line with a 'T', and add an extra port(s) as needed?
I would have thought of putting the Neptune to the far left, mainly for gas and venting.....but this works too...... or wait until I get there and install a line for you..... |
Post# 994144 , Reply# 5   5/14/2018 at 10:05 (2,166 days old) by neptunebob (Pittsburgh, PA)   |   | |
