Thread Number: 75755
POD |
Post# 995871   6/1/2018 at 04:00 (2,127 days old) by norgeway (mocksville n c )   |   | |
Oh if Speed Queen would make the EXACT SAME MACHINE today |
Post# 995890 , Reply# 1   6/1/2018 at 08:17 (2,127 days old) by turquoisedude (.)   |   | |
Post# 995907 , Reply# 2   6/1/2018 at 11:20 (2,127 days old) by speedqueen (Metro-Detroit)   |   | |
Post# 995910 , Reply# 3   6/1/2018 at 11:46 (2,127 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 995938 , Reply# 4   6/1/2018 at 17:24 (2,127 days old) by cuffs054 (MONTICELLO, GA)   |   | |
This is what I had in mind when I posted about going back to solid tubs. All the water that would be in the outer tub could be covering my clothes in the inner tub. |
Post# 995952 , Reply# 5   6/1/2018 at 21:13 (2,127 days old) by Washerlover (The Big Island, Hawai’i)   |   | |
Post# 995974 , Reply# 8   6/2/2018 at 09:04 (2,126 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
The dryer was wider than the washer, probably close to 30" for sure. It had a solid drum, heat coming in from a perforated back. Built like a tank, there was a heavy metal box that contained the heating element behind the drum near the floor on the lower right side (facing front) and the exhaust fan was at the upper left rear of the machine. The fan pulled air through the door screen, a duct around the opening and then out the back top left corner. The ducting could be directed to a vent to the outside or through the panel top and into the room.
I had the gas version of this POD, it worked for a while before the gas valve went bad. Low air flow made it a slower but fluffy- soft results. |
