Thread Number: 75789
/ Tag: Modern Dishwashers
Kenmore elite to Asko curb find |
Post# 996213   6/4/2018 at 21:39 (2,151 days old) by Stopmeister72 (Irving, TX)   |   | |
My neighbor across the street had this out on the curb. The impeller had stripped so got a new pump today. Putting this in place of my Kenmore Elite Ultra Wash which does well but needs a grinder and is now leaking rinse aid. pain in the butt to get the pump in, very tight quarters. Enjoy the pics. Nothing prerinsed. The measuring cups have solid candy melts in them and alot of it. The Asko needs a new upper washarm suporrt hub. When the upper rack is in the lower position, water comes out the top inlet port so not enough pressure to the arm. Work ok in the top position. Guess there is a bad or missing rubber check valve flapper. Will see it did tomorrow. Also went into the program mode and set it to super rinse which adds two more rinses. Anyone else have an Asko?
CLICK HERE TO GO TO Stopmeister72's LINK |
Post# 996411 , Reply# 2   6/6/2018 at 17:54 (2,149 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
What does each picture correspond to the cycle shown? On the Askos, I've seen each picture of types of dishes being washed. |
Post# 996416 , Reply# 3   6/6/2018 at 19:54 (2,149 days old) by Stopmeister72 (Irving, TX)   |   | |
Things came pretty clean, used the heaviest cycle with extra temp and dry. The only issue is the food processor bowl had some debris left on the top but there isnt a third wash arm at the top- really could use one. Think there
Was too much candy metls in the load, for the detergent and the machine, the water left in the sump was rather murky so re ran. Have put two layers of reflectix insulation around the tub. Also did a short video. |
Post# 996417 , Reply# 4   6/6/2018 at 20:20 (2,149 days old) by Stopmeister72 (Irving, TX)   |   | |
Link to video. GE not sure what you mean. There is a link in the first post to the manual that shows what all the icons are buttons are.
Post# 996418 , Reply# 5   6/6/2018 at 20:32 (2,149 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
I had a model 1585 back in 1999 and loved that dishwasher. Not as quiet as current machines, but from the D&M Roper, it was heaven. Used >5 gallons on the normal cycle, heated water to 165-170 on the heavy/pots & pans. The fan dry was equally as good as those on KitchenAid and others with fan-assisted dry.
The Euro dimensions and racking took some getting used to, but once you got over the hump, it held a ton of dishes. Asko covered the control board and new racks about about four years, then I moved it to my mom & dad's for another 5 1/2 before it needed another control board and we let it go. I remember seeing your model in the store, always wondered how the spray tubes performed. I have a friend with the 2 rack version Asko, similar age, and he swears by it. It always delivers good results and he's never had a repair issue. |
Post# 996500 , Reply# 6   6/7/2018 at 18:19 (2,148 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
Yes. I am referring to the cycle icon. For example, the normal cycle with a teacup and a dish. |
Post# 996501 , Reply# 7   6/7/2018 at 18:32 (2,148 days old) by johnb300m (Chicago)   |   | |
Post# 996533 , Reply# 9   6/7/2018 at 22:52 (2,148 days old) by Stopmeister72 (Irving, TX)   |   | |
The right tray in the middle rack pops out and you can also take out the entire middle rack to acommodate larger plates. It has a holder on the back of the machine that holds a loop in the drain hose. I had it laying over the sink so it is possible that it held too much water in the hose and it flowed back. Also, there was probably about a cup worth of solid candy melts (almond bark) in those two measuring cups during that load. It uses very little water for each fill so that may have been why. Not sure if there is a check valve on the drain pump but it does pump out well.
GE, first post- click on the link and look at page 9-10. It explains all the cycles and options. This next link is the parts list and program options at the very end. It doesn't explain what the paramiters are for the 4 variant modes to the cycles. Set it on the 4th variant and can now use the speed setting on all cycles and it cuts an hour off the heavy cycle without the speed button on with the 4th variant programmed. CLICK HERE TO GO TO Stopmeister72's LINK |
