Thread Number: 75805
New dryer - Living in student-heaven |
Post# 996382 , Reply# 1   6/6/2018 at 12:39 (2,122 days old) by johnb300m (Chicago)   |   | |
Post# 996424 , Reply# 3   6/7/2018 at 01:46 (2,122 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 996445 , Reply# 9   6/7/2018 at 09:14 (2,121 days old) by Rolls_rapide (.)   |   | |
= sliding oven door with trays. Basically, a type of drawer system. |
Post# 996457 , Reply# 10   6/7/2018 at 11:08 (2,121 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 998603 , Reply# 15   6/27/2018 at 18:00 (2,101 days old) by ozzie908 (Lincoln UK)   |   | |
I had the beko heat pump dryer for 3.5 years and there were 2 things that I hated but thought it was just me being picky....
1 it tangled all bedding no matter what cycle was used 2 that hateful black sponge filter on the condenser it used to drive me nuts cleaning it. Sold the beko to replace it with a John Lewis = AEG in disguise and wow what a difference you select bedding and it reverses equally and thus untangles the sheets it also dries very evenly and there is NO sponge filter just a second sealed almost like fine gauze one that you vacuum or brush clean every so often. I am pleased the Grundig is the same as I had contemplated one when my AEG dies but if they didn't improve the filter system or the tangling issue I will buy another AEG instead as sadly Miele heat pump dyers I believe have an omnidirectional motor so no good for fitted sheets. Austin |
Post# 998749 , Reply# 18   6/28/2018 at 21:26 (2,100 days old) by rapunzel (Sydney)   |   | |
That's not very green, is it? Since they don't really recycle these products do they ship them to Africa or do they end up in local landfill? |
Post# 998763 , Reply# 19   6/29/2018 at 05:59 (2,100 days old) by logixx (Germany)   |   | |
Post# 998768 , Reply# 20   6/29/2018 at 07:04 (2,100 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Possibly, yes. But on the other hand some airconditioners have run for a long time, so that might happen to heat pump dryers too. So far I like my heat pump dryer, I'll see how it turns out in the end.
The shirt's cycle on the Grundig, is that a cycle too that partially dries the shirts so they can be hung up? |
Post# 999389 , Reply# 23   7/5/2018 at 12:19 (2,093 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 999396 , Reply# 24   7/5/2018 at 13:07 (2,093 days old) by iej (.... )   |   | |
Large load of towels to "Extra dry" 0.8kWh* (Spun out at 1600rpm) *Sourced from 100% green energy. CO2 output 0g 1 kWh is 14.04 Euro cents. Cost of load 11 cents (€) Or: (At Google's rates) US$ 0.12 £0.09 Can$ 0.16 Aus$ 0.17 |
Post# 999473 , Reply# 25   7/6/2018 at 04:48 (2,093 days old) by Rolls_rapide (.)   |   | |
Regarding "super fast in this warmer weather..." Does that also mean that heatpump dryers are possibly more problematic in a cold room, in the middle of winter (eg. room temp of 9°C)? |
Post# 999477 , Reply# 26   7/6/2018 at 06:21 (2,093 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
Will slow them down. Heating power is minimal, so a hot start makes far more of a difference. Most state operating temps between 5 and 35C. |
Post# 999511 , Reply# 31   7/6/2018 at 12:48 (2,092 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
Yes, Acrelik makes a lot of stuff today... |
Post# 999949 , Reply# 33   7/10/2018 at 19:06 (2,088 days old) by ozzie908 (Lincoln UK)   |   | |
In winter the shower room where the washer and dryer reside is slightly cooler than the rest of the house but not by much and it never goes down anywhere near 5c as I have read they don't work too well in really cold places.
It must be affected by warmer rinse water too as it must knock a good 20 mins off the drying time I only notice its shorter when I realise the dryer is doing its anti crease bit much sooner than I am used to. I also have a vented dryer in the shed for doing dog bedding as the hairs in the inside machines drives me nuts so have a separate one its an old Zanussi from 2001 - 2002 still going strong. Prefer the gentleness of the HP on clothing though as why wash warm and cook to dry :) |
