Thread Number: 75873
/ Tag: Ranges, Stoves, Ovens
How can I fix it |
Post# 997244 , Reply# 1   6/15/2018 at 13:41 (2,134 days old) by RP2813 (Sannazay)   |   | |
Assuming it's not the bulb or the fan motor, you may just need to replace switches for both. Testing the bulb is easy. Testing the fan motor I'm not so sure about.
Replacing the entire hood isn't a big job. New ones look basically the same as what you have there, although they won't likely be available in brown. |
