Thread Number: 75883
/ Tag: Refrigerators
My new addition! :-) |
Post# 997288 , Reply# 1   6/15/2018 at 22:57 (2,113 days old) by ea56 (Cotati, Calif.)   |   | |
Post# 997293 , Reply# 2   6/16/2018 at 01:30 (2,113 days old) by tolivac (greenville nc)   |   | |
I always see boxes like that at old radio station transmitter sites-back when they were manned.And-the plant is now unattended-but the old fridge STILL WORKS!!!Even though it haden't held the engineers lunch in several years! |
Post# 997305 , Reply# 4   6/16/2018 at 05:30 (2,113 days old) by retro-man (- boston,ma)   |   | |
I have found that 24 hours is needed for fridges and a/c's that have been moved or place in an abnormal position for periods of time. Might want to shut if off and wait and see tomorrow. Jon |
Post# 997308 , Reply# 5   6/16/2018 at 06:15 (2,112 days old) by appliguy (Oakton Va.)   |   | |
Retro-man is right you have to wait at least 24 hours for the oil to settle backdown into the compressor because when you lay a fridge on its side or back the oil in the compressor can work its way into the coolant lines. If you do not let the fridge sit upright for 24 hours so that the oil can resettle you will force the oil through the lines and it can clog the one way valves in the coolant system. If all the valves get choked then it burns out the compressor but since you only transported it on it side maybe only some of the valves got clogged and that might be the reason that part of it gets real cold and part of it does not. PAT COFFEY
P.S. According to my research your fridge is from 1947. |
Post# 997358 , Reply# 7   6/16/2018 at 16:32 (2,112 days old) by Ajc31980 (Windber PA)   |   | |
Additional thought ... I forgot to mention that the previous owner said the fridge had not been turned on in over a year. Idk if that makes any difference or not. Just a little extra information |
Post# 997363 , Reply# 8   6/16/2018 at 17:01 (2,112 days old) by Ultramatic (New York City)   |   | |
Post# 997377 , Reply# 10   6/16/2018 at 20:45 (2,112 days old) by cuffs054 (MONTICELLO, GA)   |   | |
Very nice looking box. |
