Thread Number: 75952  /  Tag: Modern Dryers
duet dryer
scroll >>> for more items
Post# 998158   6/23/2018 at 15:27 by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)
hello to all aw members as this ever happen to any members who owns a generation 1 duet dryer turn on the dryer after the load is in but when pressing start dryer drum do not turn and see the sensing light on I supect a fryed control board but if my mom and I decide replacement I am considering the speed queen tr 7 top load washer with matching dryer
Post# 998217 , Reply# 1   6/24/2018 at 07:24 by wft2800 (Leatherhead, Surrey)
I would NOT ditch the Duet washer for the POS Speed Queen... if the dryer is beyond repair (unlikely!) then just get another dryer.
Post# 998224 , Reply# 2   6/24/2018 at 08:00 by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)
if the dryer is replace the washer will also be replace since my mom and I went a match set
Post# 998325 , Reply# 3   6/25/2018 at 03:58 by wft2800 (Leatherhead, Surrey)
Seriously - don't do it! The Duet will wash circles round the SQ. If you must have a matched set with a new top-loader, go for the new commercial Maytag.
Post# 999102 , Reply# 4   7/2/2018 at 19:35 by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)
update on duet dryer
Hello to all aw member here an update on the dryer a service tech has been called will come Wednesday and from a youtube vid that I watch seem the problem is a small trigger switch near the motor that broke will keep this thread updated and post an update once the dryer is repaired
Post# 999291 , Reply# 5   7/4/2018 at 16:03 by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)
a new update
a new update on the dryer the dryer is repaired turns out it was the termal fuse that fry the tech install a new fuse and dryer is now repaired
Post# 999298 , Reply# 6   7/4/2018 at 17:22 by appnut (TX)
appnut's profile picture
Terrific Pierre.  Glad it worked out that way.
Post# 999302 , Reply# 7   7/4/2018 at 17:53 by Lorainfurniture (Cleveland )
Did he clean out any lint? The thermal fuse blows for a reason. (Overheating)
Post# 999305 , Reply# 8   7/4/2018 at 18:23 by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)
Loraine furniture the tech said it was normal use no over heating nothing just the fuse just went out normal since its a 13 year old dryer dating back from 2005 and 2 years ago the dryer underwent a cleanup by the same service tech that repaired the dryer today
