Thread Number: 75989
/ Tag: Vintage Dishwashers
Kenmore dishwasher - year built? cycle descriptions? |
Post# 998426 , Reply# 1   6/26/2018 at 11:11 (2,129 days old) by Yogitunes (New Jersey)   |   | |
that dishwasher is a Kenmore UltraWash from 1987-90ish era.....most likely a porcelain tub, and a center tower that feeds the upper wash arm...
post the model and serial numbers and we should be able to date it exactly.... the cycle sequences...wash-rinse-dry....will be the same whether electromechanical, pushbutton, or touchpad... |
Post# 998428 , Reply# 3   6/26/2018 at 11:23 (2,129 days old) by appnut (TX)   |   | |
Post# 998433 , Reply# 4   6/26/2018 at 11:58 (2,129 days old) by Revvinkevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Try looking around the door edge and door frame for the model / serial data tag.
Post# 998464 , Reply# 5   6/26/2018 at 17:37 (2,129 days old) by appnut (TX)   |   | |
Rinse & Hold--2 rinses. Light Wash--main wash and 2 rinses and dry Water Miser --rinse, main wash, 2 rinses, and dry (final rinse heated to 140 probably) Normal Wash-wash, rinse, main wash, 2 rinses, and dry (final rinse heated to 140 probably) Pots & Pans--heated wash, rinse, heated main wash, rinse, heated rinse, dry
Water Heat option will heat water in the main wash to 145 degrees Hot Rinse option heats the final rinse water from 140 to 145 or 150 degrees. |
Post# 998467 , Reply# 6   6/26/2018 at 17:54 (2,129 days old) by Yogitunes (New Jersey)   |   | |
the model number plate should be just inside the door opening on the lower right hand side....
if Mark chimes in....he just found one of those machines brand new untouched....he would have a model number that would work for you..... that machine will clean the chrome off a trailer hitch......in fact, you can bake and frost a chocolate cake...place inside...and it will be gone by the end of the cycle....GUARANTEED!!!....that was the UltraWash Challenge, trust me, I did it a number of times.... |
Post# 998507 , Reply# 7   6/27/2018 at 04:13 (2,128 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)   |   | |
Can I try that in my brand new Kenmore? Please say yes, please say yes! ROFL |
Post# 998664 , Reply# 8   6/28/2018 at 06:02 (2,127 days old) by askolover (South of Nash Vegas, TN)   |   | |
Post# 998713 , Reply# 10   6/28/2018 at 14:32 (2,127 days old) by vacerator (Macomb, Michigan)   |   | |
Mark V Imperial power clean without the hiding console. |
Post# 998730 , Reply# 11   6/28/2018 at 16:36 (2,127 days old) by appnut (TX)   |   | |
