Thread Number: 76036  /  Tag: Wringer Washers
1937 Maytag Model 32 Wringer Washer Gearbox Mechanism Removal?
scroll >>> for more items
Post# 998912   6/30/2018 at 16:24 by MaytagWasher18 (Calgary Alberta Canada )
maytagwasher18's profile picture
Hello Everyone,
I am currently in the process of fully restoring my 1937 Maytag Model 32 Electric Wringer Washer. I have recently disassembled the gearbox in my machine to change out and replace the grease as well as to replace the gasket seals.
This is my first restoration on a vintage appliance so I have one or two things I don't really know about its design yet, however, I have learned lots about it so far.  I have made good progress on the restoration but I am currently having trouble figuring out how to remove some of the internal mechanisms on the machine or if the mechanisms are even designed to come out. I am unsure of this because some of the mechanisms appear to be fastened in with some sort of pin. I have tried to remove them several times but I am unsure if they are either rusted in place or if they even designed to come out in the first place.
Any information would be greatly appreciated.
Thanks!
-MaytagWasher18
  Photos...       <              >      Photo 1 of 5         View Full Size
Post# 998949 , Reply# 1   7/1/2018 at 01:48 by bradross (New Westminster, BC., Canada)
Glad to share my experience...
bradross's profile picture
I restored a Model 32 last year, having had previous experience on the Model 30 (which used the same power unit.) The three pieces I did not remove were the worm screw, gear with eccentric on top, and the pinion gear shifter yoke. I didn't deem it necessary, as they were in fine shape and I could clean the old grease from out around them.
Hope my photos on Flickr will be of some usefulness to you. Any questions, don't hesitate to ask!
Also, have a few videos of the process on YouTube under username "BradRoss63".
CLICK HERE TO GO TO bradross's LINK
Post# 998972 , Reply# 2   7/1/2018 at 09:29 by MaytagWasher18 (Calgary Alberta Canada )
This post has been removed by the member who posted it.
