Thread Number: 76061
/ Tag: Air Conditioners
Finally a mini split portable air conditioner. |
Post# 999119   7/3/2018 at 00:17 (2,118 days old) by petek (Ontari ari ari O )   |   | |
This is the first one I've seen.. I noticed it on the costco canada website.. but that ones is 10,000 btu and $999 Cdn. May have to consider one for our upstairs.. the portable ac is very noisy. And I like how it has a window hanging bracket
CLICK HERE TO GO TO petek's LINK |
Post# 999123 , Reply# 1   7/3/2018 at 00:46 (2,118 days old) by petek (Ontari ari ari O )   |   | |
Post# 999124 , Reply# 2   7/3/2018 at 00:58 (2,118 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
I had a portable split one, bought it used about 7 years ago or so. It was a 22,000 btu one or so. I used it for a year, the next year it did nothing anymore. It was very heavy, you needed three people to move it. Two for the part for inside and one for the part outside. The hoses are very vulnerable, you need to be careful with them. But when they work they work really well, way more efficient than a single portable one.
Post# 999127 , Reply# 3   7/3/2018 at 01:47 (2,118 days old) by petek (Ontari ari ari O )   |   | |
Post# 999133 , Reply# 4   7/3/2018 at 03:59 (2,118 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 999143 , Reply# 5   7/3/2018 at 06:33 (2,118 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Are probably a good idea because MS A/Cs are basically throw away A/Cs anyway and now you won't have to drill holes in your walls and tear up a home to have one.
MSs are more advanced and therefor use less power and operate more quietly, standard window A/Cs could be just as efficient but people will not pay $500+ for efficient window A/Cs so we are getting stuck with MS systems in the US as a poor alternative to real split system A/C and heat-pump systems.
MS systems tend to do a poor job controlling humidly because they usually keep the inside fan running all the time thus evaporating a lot of the moisture they capture right back into the room as soon as the compressor shuts off. They as also very poor at filtering more than large dust particles from the air [ standard window A/Cs have the same problem ] Permanently installed ducted split systems in the US usually have advanced hi efficiency filters and even electrostatic filters that literally catch almost all particles that are harmful to humans.
We even put this type of air-cleaning system in the warehouse to clean the air in the shop and offices. When we take the collector cells out and wash them in a DW the water literally turns dark gray to black and the electrostatic filter is in the air-stream AFTER a standard filter like MSs have and then a 4" thick high efficiency pleated filter.
Post# 999168 , Reply# 6   7/3/2018 at 10:09 (2,117 days old) by philcobendixduo (San Jose)   |   | |
....and here is the link to that post. Scroll down almost to the end OR search for "Freecom" in the "Super" forum.
Since I got central A/C installed in 2014, I no longer have these units. I gave them to a friend of mine. He stashed them in his garage and then they and everything else in the garage was lost in the "great San Jose Flood" of 2017. VERY hard to find these and the were VERY expensive to purchase new. I found one for $400 used and another "demo" for $1000 from a dealer in Montana. They ARE the most efficient of the "portable" A/C units. Those with exhaust hoses just suck cool air right out of the room and send it outside PLUS the exhaust hose just adds more heat load to the room since it gets quite hot when in operation. CLICK HERE TO GO TO philcobendixduo's LINK |
Post# 999171 , Reply# 7   7/3/2018 at 10:17 (2,117 days old) by philcobendixduo (San Jose)   |   | |
....for the portable split A/C system that I had 2 of.
So, this new one is NOT the first ever portable mini-split. |
Post# 999191 , Reply# 8   7/3/2018 at 13:15 (2,117 days old) by MattL (Flushing, MI)   |   | |
Wow! Perfect solution for a relative in need of one of these. Thanks! |
Post# 999205 , Reply# 9   7/3/2018 at 14:43 (2,117 days old) by petek (Ontari ari ari O )   |   | |
Post# 999271 , Reply# 10   7/4/2018 at 09:26 (2,116 days old) by philcobendixduo (San Jose)   |   | |
....between this new unit and my old Freecom is that the compressor on the Freecom was located in the INSIDE unit which did increase the noise level somewhat. I always wondered why they didn't install the compressor in the OUTSIDE unit and now, this NEW unit has addressed that issue.
The "umbilical" cord looks much the same on both units and it IS fragile. Contains 2 refrigerant lines, power cable and drain tube so it can be a bit unwieldy. |
