Thread Number: 761
New GE Profile FL not functioning properly, any ideas? |
Post# 51131 , Reply# 2   12/15/2004 at 15:40 (7,043 days old) by maytagbear (N.E. Ohio)   |   | |
Before calling the store, have you thoroughly read the Owner's Manual? Another possiblity is calling GE's 1-800 number. I know that some coin-op front loaders run a very similar sequence while starting. Lawrence/Maytagbear |
Post# 51192 , Reply# 5   12/16/2004 at 09:35 (7,042 days old) by frigilux (The Minnesota Prairie)   |   | |
I know it's disappointing to get a new appliance that malfunctions right away. On the plus side, if it's an electronics problem, they can replace the timer or a circuit board and you're good-to-go. You always want your electronics to fail immediately (if they're going to fail) so that replacements are fully covered by the warranty. Once the 'bum' electronic part is replaced, you'll probably never have trouble with it again. Is there some 'play' in the door when it's closed? Start the machine and once it has filled and is tumbling, give the door a little tug. If the machine stops, a serviceman will tighten or replace the saftey lock on your door. If you're washing a big load and the clothes press against the door while tumbling, a loose or faulty safety lock will cause the machine to stop, as if you pushed the cycle knob in. I've had 2 Frigidaire versions of your machine (a 1996 and a 2003) and had great luck with both of them. The 1996 model is still being used in a multi-family apartment building and going strong. Good luck and may you have many trouble-free loads in the future. Once your machine is working properly, you'll love it! |
Post# 51241 , Reply# 6   12/16/2004 at 21:58 (7,041 days old) by laundromat (Hilo, Hawaii)   |   | |
On all the FriGEMores,as soon as the wash water is draining out,fresh water sprays in to rinse out excess suds,lint and scum.This goes on for about a minute.then it goes either into a short spin or fills for the first deep rinse.Have you given it a chance to procede,or are you just assuming that the spray rise/drain was a faulty procedure?
Post# 51595 , Reply# 11   12/22/2004 at 13:10 (7,036 days old) by westytoploader ()   |   | |
Seems like the pump is not shutting off after the first spin before it fills for the rinse. Could be a defective timer, but I'm not sure. |
Post# 57687 , Reply# 16   2/19/2005 at 14:41 (6,977 days old) by scott55405 ()   |   | |
Kay, I'm guessing you meant to say you won't buy a toploader again, based on the rest of your post. I'm glad you got your problem resolved and that it was something simple! Scott :) |
Post# 57729 , Reply# 17   2/19/2005 at 22:21 (6,976 days old) by KayW ()   |   | |
Sorry for the error!!!! -Kay |
