Thread Number: 76131
/ Tag: Modern Dryers
Well... That got interesting quickly! |
Post# 999676 , Reply# 1   7/8/2018 at 03:09 (2,112 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Post# 999698 , Reply# 2   7/8/2018 at 10:52 (2,112 days old) by Dustin92 (Jackson, MI)   |   | |
Yeah the yellow powder was from the fire extinguisher, it was super fine and got into everything. Also pretty irritating to the nose. |
Post# 999720 , Reply# 3   7/8/2018 at 15:37 (2,112 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Post# 999772 , Reply# 5   7/9/2018 at 07:13 (2,111 days old) by askolover (South of Nash Vegas, TN)   |   | |
Post# 999965 , Reply# 7   7/10/2018 at 23:40 (2,109 days old) by Spinmon (st. charles mo )   |   | |
"I hates those meeces to pieces". You could check for critters 100 times and zip. That ONE time no checky and... At least the fire was contained. |
Post# 1000081 , Reply# 12   7/12/2018 at 06:42 (2,108 days old) by Rolls_rapide (.)   |   | |
That won't work if the motor is the component which has failed. |
Post# 1000105 , Reply# 13   7/12/2018 at 12:56 (2,108 days old) by Tomturbomatic (Beltsville, MD)   |   | |
Motors are generally thermally protected, but a rare short could occur. Add to what I said, "unplug the dryer." |
Post# 1000164 , Reply# 15   7/13/2018 at 07:06 (2,107 days old) by askolover (South of Nash Vegas, TN)   |   | |
Post# 1000171 , Reply# 16   7/13/2018 at 11:29 (2,107 days old) by Tomturbomatic (Beltsville, MD)   |   | |
This was not a motor; Read, Please. It was a mouse nest in the tube above the burner. Fire was coming thru the heat inlet grill into the drum. It was not coming out of the cabinet. |
Post# 1000336 , Reply# 18   7/15/2018 at 00:07 (2,105 days old) by Tomturbomatic (Beltsville, MD)   |   | |
I was just responding to the real situation as stated. You had to interject a factor which did not exist either in the situation or in the machine's construction. Gey kaken afn yam. |
Post# 1000345 , Reply# 19   7/15/2018 at 06:45 (2,105 days old) by Rolls_rapide (.)   |   | |
Dicht yer neb an flee up. |
