Thread Number: 76154
/ Tag: Vintage Dishwashers
KitchenAid Model KUDS21CA0 - Won't Start Cycle |
Post# 999931 , Reply# 1   7/10/2018 at 16:47 (2,113 days old) by WashBroke (SC)   |   | |
Model KUDS21CS0
Post# 999937 , Reply# 2   7/10/2018 at 17:27 (2,113 days old) by RP2813 (Sannazay)   |   | |
Post# 1000197 , Reply# 5   7/13/2018 at 16:04 (2,110 days old) by WashBroke (SC)   |   | |
Removed Switch assembly, there didn't appear to be anything wrong with the switch reset lever. Is there any way to determine if the switch assembly is the problem? Nothing obvious from what I can tell. |
Post# 1000198 , Reply# 6   7/13/2018 at 16:16 (2,110 days old) by bigalsf (Salt Lake City)   |   | |
If the reset cam is functioning correctly then the switch is the problem and must be replaced. It is not repairable. Your can still get this part via most appliance parts dealers or on eBay. You will need the part number from the back of the switch |
