Thread Number: 76471
Mile 1215 worth it in the end? Hello new W1 |
Post# 1003187   8/10/2018 at 10:49 (2,083 days old) by UncleDave (California)   |   | |
I say goodbye to my old friend the Miele W1215 and make room for a new W1.
I have mixed emotions about this. I did NOT get 20 years out of the unit, it's leaving not quite at just under 14 years so significantly less. I DID get approx 11K cycles out of it or approx 11K hours of use. I had it serviced at 10,250 cycles a while back and its developed a mystery spin problem along with a torn boot and I'm just not going to invest any more service in a platform with so many spin cycles on it. If it were a car driving at 60 MPH that'd be 660,000 Miles - a lot of miles to be certain. It laundered a family of 4 w 2 teenage boys, 3 beds, 3 dogs and their bedding, towels for the pool, and a sanitize load per day for 5 years for my wife's pet grooming business - it had a hard hard life. Good bye old friend..... Uncle Dave
Post# 1003218 , Reply# 2   8/10/2018 at 18:53 (2,083 days old) by UncleDave (California)   |   | |
Already gone.
I'm happy to see some capabilities and bummed others seem to be gone. I knew with only 110V and like 20 amps I wouldn't be getting really hot water really fast. Just spinning full speed will speed up my whole scenario dramatically- I was coming out of the washer with a full load of wet towels nightly that were taking 2.5 hours to dry. The machine was also adding a rinse mysteriously every "x" wash pushing out the wash times to about 1:20 UD |
Post# 1003310 , Reply# 3   8/11/2018 at 13:12 (2,082 days old) by richimaor (Baja California, Mexico)   |   | |
I’ll be thrilled to hear about the performance of the 110V Miele! |
Post# 1003333 , Reply# 5   8/11/2018 at 16:18 (2,082 days old) by UncleDave (California)   |   | |
Hello Henene4.
I don't feel I got gypped, some might calculate that Im not really saving much, but I value the performance. My pw6065 is supposed to be more industrial and last to 15K but well see about that. It wasn't the shock absorbers, as all were replaced approx 700 cycles ago, as were the carbon brushes. Perhaps I should have replaced the springs as well?? The torn boot was from a shoe that ripped the lip off the top- it was still sealing, but underneath the torn "lip" was an aggressive surface (stiff ribs) that quickly took out anything that rubbed against it. The logic had begun randomly adding rinses as well. It was simply time. So far the W1 has had 7 or 8 loads through it already and it's been a gem- more aggressive in the washing a more aggressive ladle set in the drum. Ive run mostly twindos and so far I like it. The detergent tray is a bit different with a "liquid" insert in what was the powder tray, I removed for the persil powder I have 100's of "Waschen" left that I really like. UD |
Post# 1003340 , Reply# 6   8/11/2018 at 17:04 (2,082 days old) by UncleDave (California)   |   | |
Henenen - Yes I believe I have the power wash 2.0 -that the secondary recirculator and filter right?
(Miele has an excellent filter) W1 - Im awaiting delivery of the plinth which is a few weeks out so I reassembled the area and started at it the laundry right away. . Old unit was really quiet. The new machine is even quieter. I found what I needed in terms of matching my old 1215 - " Normal +Hot(60C)+Max Spin=59 min". W1 Quickintense + Hot+=59 min. Note the new definitions - old "hot" was 60C. Which is now defined as "HOT+" That said The machine is equal or FASTER in my daily 60C wash than the 220V machine ( ?!??! shouldn't be but it is) while having better balance logic in the spin, a more aggressive wash, and the recirculation pump. Its a better washer, the higher speed powerwash agitates more than the older machine did in its limited range of fixed speeds. So far I'm pretty damm impressed. Note suitcase full of laundry the "adult" offspring units show up with every Saturday. They are more than happy to avoid the 4.00 per cycle (4 wash +4 dry x 4 loads a week) + soap charge to do it at their apartment and slowly end the life of my machines.....remaining firmly clamped onto the teat of the parental hardware, water, energy, and soap for what must be the worlds longest duration. I digress- TWiNDOS currently set at 22 ML phase 1 and 15 Ml phase 2. End up with just a few suds in the wash and rise. Perhaps unsurprisingly the oxygen bleach works (which is why we use sodium percarbonate at times) produces very slightly crisper whites than white Persil alone. It's a nice feature that isn't marketing hype. Its a bit Kafkaesque to have to override twindos every time you want to use regular soap but retaining the powder, handling, (while improving the liquid dosing drawer) had to "default" some standard - and unsurprisingly they made Twindos the default. Thats said it works great and is dead easy to use. I/we likes the Twindos smell - I was worried about that. UD
Post# 1003376 , Reply# 7   8/12/2018 at 00:01 (2,081 days old) by littlegreeny (Milwaukee, WI)   |   | |
Post# 1003416 , Reply# 8   8/12/2018 at 12:01 (2,081 days old) by UncleDave (California)   |   | |
Thanks, I'll check that out
I pretty much just check up using the app now through the phone- bit of a pain setting it up but finally got it. Thrilled with it so far. In retrospect, I don't think 1215 had much if any balance logic. This machine had a tricky 2 large rug load and spent 3-4 minutes before getting the balance just right UD |
Post# 1003442 , Reply# 9   8/12/2018 at 19:03 (2,081 days old) by jerrod6 (Southeastern Pennsylvania)   |   | |
I think you can change the words 'Hot" "Warm" in the display to the actual temperature numbers. Check the user manual under settings. I think you can also change the spin speed words to numbers like the previous models too. |
Post# 1003782 , Reply# 10   8/15/2018 at 14:02 (2,078 days old) by UncleDave (California)   |   | |
Thanks, Jerrod, I'm having a bit of trouble finding that, but it's not really a big deal.
Ok so this thing is pretty awesome - I've had it filled to the brim twice now with 17.5 pounds of rugs, 17.5 pounds of mixed towels plus 2 full-size cotton chaise lounge covers (i put a basket on the bathroom scale) and each time it found really good balance and spun up to full RPM. One time it took 4 minutes extra to balance itself - which I vastly prefer to an abort or slow speed spin giving me hours in the dryer. Even at its own relative max weight, my 1215 got flummoxed by the same mix of large and small items failing to reach full RPM spin quite often in its latter days. It rightfully used some water - 78 Litres per cycle -but the final rinse was super clear. I've seen some cycles use VERY little water 13L in some modes, but Ive got all kinds of adjustability to tweak whatever I want vs the 1215's limited programmability. Ive now cut 4 loads down to 2 and shaved tons of time and energy from my drying cycles. |
Post# 1003785 , Reply# 11   8/15/2018 at 14:53 (2,078 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
Of this manual (Unit setting): www.mieleusa.com/pmedia/Z... |
Post# 1003807 , Reply# 13   8/15/2018 at 20:55 (2,078 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Hi D, The HP dryer will take 2-3 times as long as the gas dryer did, and cost a little more to run as well, your clothing will also wear a little more with all those extra HOURS in a dryer.
What part does your Miele gas dryer need?, for such an expensive product it is really amazing that they won't back it up, one could just buy a Samsung or LG if they wanted this kind of crappy support.
Post# 1003816 , Reply# 14   8/15/2018 at 23:12 (2,077 days old) by UncleDave (California)   |   | |
DBV- Its sitting on a pedestal now and still super smooth.
Smoother than my 1215 even with loads it could never balance. Would i buy again at this stage - yes absolutely. I really like the twindos so far, and at 20 ML per dose Im getting way longer than I though- 75 vs 35 loads for about 20 bones. The oxygen bleach phase 2 works better than a big dump of oxy powder. in places They took some money out of it - the top is cheaper, the door is cheaper, The enamel is great, the drum is great and the selector know and panel feel great. The settings are a bit arcane from what was straightforward but overly simplified 1215 Arcane in that the weight limit varies dramatically from load to load, some setting don't have full temp or spin ranges - but I found what I needed that was close enough to be happy. The control app is kind of 1.0- not much more than a status indicator of where the machine is in a given load and what the parameters are.I wish it had some ability to cumulatively track KWH and water usage - it can read these in real time, but not store them. Happy i don't need a new dryer yet - my 220V 1405T works just great. UD |
Post# 1003831 , Reply# 17   8/16/2018 at 06:38 (2,077 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
Those are EU platform machines. There are VERRY few gas dryers in the EU, and Miele will not make the same mistake again and try to make an exclusive design for a new market. Cycle times are highly dependent, but more then 90min is rare. But a vented dryer will be quicker. |
Post# 1003852 , Reply# 18   8/16/2018 at 11:22 (2,077 days old) by UncleDave (California)   |   | |
The pedestal arrived yesterday and I had to fiddle with the feet and position so the drawer would clear the lip and door opening - took a while but shes leveled and ready - probably time to peel off the twindos sticker.
Henene - Quick intense wash doesn't let me use cold water it only goes down to warm+. For my preference thats too warm for dark clothes which I usually wash on cold or 20. The dark/denim load lets me go to cold but maxes out at 1400 RPM spin for darks, I typically use the normal/cold/max setting which results in a 1:20 wash cycle. It would be nice to find a 1-hour mode with the temp and spin flexibility. Ive used the singles modes a couple times now to good success but didn't sit in front of the machine to see exactly how the standard mode got chopped down. UD
Post# 1003890 , Reply# 19   8/16/2018 at 20:18 (2,077 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
As noted, file it under "been there and done that".
Miele made a gas dryer to match their uber sized 4XXX series washing machines, and it was nearly a universal failure. Too many problems, bugs and whatever, especially for what was supposed to be a high end appliance (with a price tag to match). Equally as duly noted gas (natural or propane) are rare in Europe especially domestic. You might find them in commercial/industrial laundries, but still... Thus Miele does not have a large natural market for gas dryers, and never again it seems (after the hot mess that was the 4XXX series) will they go down the path of producing region specific washers and dryers. Things sold in North America are merely tweaked versions of what is sold elsewhere. Miele also stopped selling vented electric dryers in North America some time ago as well. Long before the heat pump versions arrived only thing one could get was a condenser version. At least new; there are plenty of old/used ones on market. |
Post# 1003891 , Reply# 20   8/16/2018 at 20:22 (2,077 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Theory behind limiting spin speeds for denims/darks is to prevent those white "crease" marks that can come from too high final extraction speeds.
IIRC many other European domestic washing machines have similar programs now a days. On whole did does seem as if Miele learned from their mistakes with the 4XXX series uber sized washers and the W1 are streets ahead. If and or when Big Bertha goes, may seriously consider getting a W1. Though that may be years away so there likely will be something newer on market. |
Post# 1003904 , Reply# 22   8/16/2018 at 21:58 (2,076 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Can't see heat pump dryers really taking off in USA/North America.
Like ventless/condenser dyers the things do serve a purpose and fills a certain need, but don't think many will be replacing their gas or even electric vented dryers with one. Well not unless again the numbers work for them and or they see it will provides benefits that outweigh any negatives. When you consider electric or gas vented dryers can have lifespans measured in two or more decades, spending a large amount of money for a heat pump dryer that has a comparatively short life (IIRC Miele T1 units measure a decade or abit over with average use), again just don't see it becoming the next big thing. Now for those in urban settings such as here in NYC living in apartments where they cannot or will not run venting; these dryers are a game changer. Better performance than average condenser dryers and non of the drawbacks such as heating up the area. |
Post# 1003930 , Reply# 24   8/17/2018 at 08:24 (2,076 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
So am not going down that road again...
United States is a vast country and energy prices vary very much by geographical location. Here in New York electricity rates are dear: Con Edison is currently 21.0 cents per kilowatt hour, and natural gas is gas, at $1.262 per therm. Most here use natural gas for cooking, water, home heating and clothes dryers. Things may vary by type of home (older apartment buildings still largely burn oil for heat/hot water for instance). Con Edison and other utility companies in this state also tack on a vast and bewildering array of taxes and surcharges mandated by local government. All this being said when most go dryer shopping here first and foremost the decision is based upon what fuel (gas, propane, electricity) is available. Con Edison has a nifty tool to promote "energy efficient" appliances. "CLEARCOST shows you what this product may cost you to buy and run. CLEARCOST is worked out by combining the lowest available purchase price for the product that day from retailers shown on Con Edison Marketplace, with the energy costs of using the product over its typical lifetime, with the electricity rate specified, and the typical amount of usage." Several heat pump dryers dominate the top rankings with a "100" score. However the details tell another story. Whirlpool WED9290FC - Has a total cost to own and run for 16 years of $4,267 marketplace.coned.com/dryers/139... Miele TWF160WP - Is slightly better at $2,163 for same period only because of lower energy use. marketplace.coned.com/dryers/163... Kenmore Elite 61553 (vented) comes in at $3,982 with a bulk of that cost coming in energy usage. marketplace.coned.com/dryers/149... Miele T8033C - Comes in at $2,977 marketplace.coned.com/dryers/152... Rest can be looked up here: marketplace.coned.com/dryers/QUE... You can see anyway sliced electric dryers are expensive here, but there is another consideration. Many simply do not want to wait two or more hours for a load of laundry to dry. This is the same complaints many north Americans have about European laundry appliances in general; they take too long. |
Post# 1003941 , Reply# 26   8/17/2018 at 11:18 (2,076 days old) by logixx (Germany)   |   | |
Post# 1003973 , Reply# 27   8/17/2018 at 18:25 (2,076 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Yes but on that side of pond for various reasons many are used to paying more for various fuels; petrol, electricity, etc....
Here things are more complex and usually rates are driven up by local taxes, surcharges and fees tacked onto bills. Here in NYS we actually pay a surcharge to providing funding to MTA (transit), a fund for the poor who cannot pay their electric bills, and so forth. www.chooseenergy.com/elec... Again here in NYC and surrounding area there are reasons why if given a choice people will go with natural gas over electricity for things like heating, hot water, cooking, etc... Case in point; developers of new buidlings here are cheapening out by installing PTAC units instead of central heating and or air conditioning. This works out well for building owner/landlord; but for those who must heat their apartments using those PTAC or other electric units get hit with major bills. www.brownstoner.com/forum... www.ny-engineers.com/blog/can-el... |
Post# 1003994 , Reply# 29   8/18/2018 at 04:06 (2,075 days old) by logixx (Germany)   |   | |
Post# 1003998 , Reply# 30   8/18/2018 at 06:41 (2,075 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Miele had so much problems with that large gas dryer (that matched 4xxx washers), they probably simply said never again.... *LOL*
Keeping with theme of this thread, not offering a gas dryer likely will lose Miele some sales here in USA. No matter how great their heat pump dryers are, many simply are not going to switch over to electric when they have a gas connection already. This even with the Miele dryer using 120v power instead of 220v. But then again maybe Miele has accepted they will be nothing more than a niche brand in USA and are happy. |
Post# 1004013 , Reply# 31   8/18/2018 at 11:10 (2,075 days old) by ozzie908 (Lincoln UK)   |   | |
What happens when there is no gas ?
I believe Foraloysius mentioned in the Netherlands they are stopping the instal of gas boilers. We in this little island the UK have a lot of electric driers as they are the norm so anything that saves the darn elec bill has to be a bonus. There are 3 adults and 3 dogs in my home I do a lot of washing and due to having no space for a washing line have used my heat pump dryer all year round. The cost is negligible compared to the old vented dryer I use for the dogs bedding. I like my heat pump it may take longer than a vented or condenser but the no heating the room makes for a more comfortable surrounding and it takes maybe a 1/4-1/2 hour longer than the wash cycle so instead of washing everything in one day I spread it over the week. Austin |
Post# 1004015 , Reply# 32   8/18/2018 at 11:35 (2,075 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Yes, that is right. Gas heating is being phased out here. My nephew and his wife have bought a new house that has yet to be built. The new residential area will have no gas connections at all. Heating will be done with a heat pump and they are going to cook on induction.
I am using a heat pump dryer (Siemens) for some months now. The big surprise is that it gets pretty much as hot as the Miele condenser dryer I had before the Siemens. I thought temperatures would be much lower, but I guess it just takes a bit more time to achieve the max. temperature. |
Post# 1004016 , Reply# 33   8/18/2018 at 11:36 (2,075 days old) by UncleDave (California)   |   | |
speed vs money - Im kind of on the edge with one set speed wise as is, most colleagues have 2 pair of units.
This is why I put 11K cycles on in 13.8 years. Thats a bunch of laundry. Although its true I can make energy from my roof - natural gas therms are dirt cheap and although not limitless in supply, abundant enough here in the Western US that they may as well be. Having made the decision early to bias hedonism over frugality - I have very little space left for solar electric, having covered my roof with solar water heating for the pool and jacuzzi. If I only laundered for myself and wife I could care less what time the units took if they saved money, but it isn't just us - its, us, the "kids", the dogs the guests, and a business. It kind of goes like this business guests Us Kids Dogs My personal conundrum in the speed/ cost scenario is that I have a mobile grooming business to support out of my home, and its 15lb 60C load per day and drying time takes precedence over all personal items. then the kids show up at random times during the week and always on weekends and then you add in the swimming towels, lounge covers and whatever washcloths get used during pre and post swim showers. My back room has about 25% guest duty, more than most as a Sales VP at a global company I have lots of international and stateside guests and visitors, add its denizens also seem to love the pool and and associated endless supply of high end fluffy towels I supply them. 20 years ago I switched my gas appliances over to 220 to save money but it now becomes cost prohibitive as tiers and base costs have skyrocketed and tier 3 where I seem to land every month ends up at or above.21 As such at replace time -Not Germanic level, they have managed to make electricity unaffordable for nearly everyone in Germany. Same as Hawaii. I am re-seeking gas alternatives at swap out time to attempt to get back into my respective tier 1,or 2., and about to finish off the roof with solar electric even though the positioning is sub optimal Ill be able to recoup something. When the 1405 goes "a big Ole" gas dryer is going in its place. UD |
Post# 1004040 , Reply# 34   8/18/2018 at 16:51 (2,075 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Not an issue for USA atm, nor for long in foreseeable future.
Had tons of the stuff, and now thanks to our friend Mr. Fracking the United States has so much natural gas we don't know what to do with it all. Largest issue is bringing infrastructure online and or finding ways to move LNG or pipe natural gas to various parts of the country. Some of you outside this nation may have heard about Donald Trump and his "helping" the coal industry. Well coal is dying off as the remaining market for thermal coal (electric power plants)are going over to natural gas. |
Post# 1004043 , Reply# 35   8/18/2018 at 17:10 (2,075 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
To knacker a Miele washer in relatively short periods of time, now I know.
Not pointing fingers or anything, but that sort of heavy usage as outlined above is enough wear and tear on any washing machine, even those built to a higher standard such as Miele. Well they used to be anyway.... Don't think have saved the link, and have forgotten exact formula how Miele and other European washing machines arrive at lifespan estimates. IIRC however things went something like average household doing one or two loads per day multiplied by weeks and into years. This being said it does seem that Miele's boilerplate "20 year lifespan....", might be a load of flannel these days. Perhaps their old purely mechanical and or simpler electronic/mechanical washers lasted decades, but the newer pure electronic machines may be another matter. Often it is something like the motherboard or other electronics that fail after a few years. However while the machine technically otherwise is in good condition, cost of new parts and call out charges are dear (especially for Miele). So people often end up rubbishing the thing and buying new. thinks.jamesbradbury.co.uk/life-s... www.repairaid.co.uk/washi... conversation.which.co.uk/home-en... Whatever claims Miele makes regarding longevity of their washing machines (or other appliances) warranties offered do not come anywhere near. While one believes things are a bit more generous in Europe, on this side of the pond for a washer that costs nearly two or three thousand, you get a barely two year warranty. Even then it is rather limited for what one is getting. |
Post# 1004090 , Reply# 38   8/19/2018 at 04:11 (2,074 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 1004097 , Reply# 40   8/19/2018 at 06:28 (2,074 days old) by Rolls_rapide (.)   |   | |
Didn't the Dyson Contrarotator also spew such bilge? And we saw how trouble-free they were... |
Post# 1004119 , Reply# 41   8/19/2018 at 10:14 (2,074 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
You want to compare a company producing a radicly new washer design with MAJORLY more complex mechanics without ANY prior experience in appliances to a company that is in the appliance buisness about twice as long as the other company even exists at all? |
Post# 1004152 , Reply# 43   8/19/2018 at 16:39 (2,074 days old) by UncleDave (California)   |   | |
Most Miele stuff lasts a long time.
Some don't. My first blue moon vac was terrible, from cracked circuit boards to hoses with poorly integrated electronics. The new miele vac has been great Ovens have been great - only needing one repair in 15 years. Dishwasher a g851 SC is about 15 years old now and so far has not needed a single repair. Washer needed a few repairs in its 10K life but delivered excellent performance until the last 250 cycles or so. The dryer is still kicking after 11K cycles with one brush upgrade that wasn't needed but making a chattering noise. Its dam solid but not "bulletproof" or perfect stuff - good enough for me to pay the delta - so far. UD |
Post# 1004155 , Reply# 44   8/19/2018 at 17:20 (2,074 days old) by UncleDave (California)   |   | |
Another weekend another small mountain sent back to the kids....
UD
Post# 1004182 , Reply# 45   8/20/2018 at 03:50 (2,073 days old) by mrboilwash (Munich,Germany)   |   | |
Post# 1004199 , Reply# 46   8/20/2018 at 07:07 (2,073 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Is pretty much determined the number of hours its components are run and the length of time you keep it, after this the care it gets and the environment is installed in.
Miele makes a very high quality washer, but compared to a Speed Queen FL machine which is a true commercial based machine that is designed to go 25,000 loads average it is just not as rugged or repairable.
A Miele is just way too complicated and has way too many plastic fasteners holding it together, it is also much harder to service and parts are not as readily available and EXPENSIVE.
The SQ is much larger in capacity which adds to overall life because you will do up to 50% fewer loads, try stuffing an American sized comforter in a Miele.
Post# 1004212 , Reply# 47   8/20/2018 at 10:05 (2,073 days old) by UncleDave (California)   |   | |
Some items are cycle speed independent like controls and like the water fill solenoids - all they know is on and off, and I had two cold water fills fails in 11K cycles -mostly attributable to our hard water.
A slow turning spinning cycle is a "cycle" nonetheless to those components. Speed Queen I could have easily bought a speed queen last round and this round- I have the hookups and space. As for speed queens and longevity, there are some factors being left out and some assumptions being made that don't pan out equally in every scenario. If it had the same or equal features and performance as the Miele it would be a closed case and I'd be using one - - they don't. One big diff being they don't have internal heaters. They can skip using a whole lot of components by avoiding this complexity. In terms of sanitizing - for me, I need 1 full germ killing load per day - A hot water fill will not sustain 60C if it can ever even get that temp to drum onceit wont hold. This means in order to truly sanitize anything you have to resort to bleach which reduces the life of fabrics considerably and results in added expense to buy use and deal with vs hitting the 60C button and walking away. In terms of getting grease out of shop clothes sustained temps get the job done where the speed queen simply won't clean as well as a unit with an internal heater. Soap+ agitation+ heat= cleaning power. Remove the heat from the equation and the cleaning power goes down. Extra capacity doesn't always mean fewer loads - unless its so big I can put two beds in at once - it's not. Id still have to run two separate cycles for the front and back beds. I don't have any king beds in my house but 2 queens and can comfortably fit one whole beds worth in one load. If the speed queen were so big it could take two loads (closer to 30LB dry) it would make a difference to me - but it inst that big. I do a 4 bin sort - and the rest of my loads aren't full to capacity by the time I need to do them so the bigger drum doesn't buy me much if anything based on how I do laundry - If I dumped everything in one load and washed it all on cold then maybe I could see cutting a cycle or so week out but based on my sorts - the drum size increase below a 2 bed threshold buys me almost nothing. Then let's talk about the drum itself - is speed queen still using plastic ladles? Put 20 lb of dry laundry in there then get it all good and wet then drag an open zipper over that plastic a few hundred times and see if it scratches - if it does you then that scratch forever drags across your laundry. 25K cycles is a great lifespan. I don't know if they actually make it that far but if they do that's great. Thing is those cycles aren't the equivalent of the Mieles cycles from a flexibility and feature standpoint. UD |
Post# 1004219 , Reply# 48   8/20/2018 at 12:02 (2,073 days old) by appnut (TX)   |   | |
UD, thank you for your eloquent statements regarding the effectiveness and thoroughness of FLers with heaters. The European approach to doing laundry is so far superior and civilized than the wham-bham thank you ma'am way Americans do laundry in 25 minutes. I hope I never have to go back to a top loader of any kind, particularly any washer without a heater. Since I acquired a washer with a heater, my laundry is far superior in cleanliness and significant dirt/stain removal vs. the American approach.
I hope Meldew in Georgia is continuing to realize and experience the superiority of front loaders tackling horrible messes that she discovered once she got an LG washer with heater/sanitize that functioned cor4rectly and is adjusting to the longer cycle times when needed for those big messes. |
Post# 1004231 , Reply# 49   8/20/2018 at 13:53 (2,073 days old) by UncleDave (California)   |   | |
I no sooner opened my mouth about how my latest Miele vac was trouble free- and then discovered this morning - looks like the last person dropped it and broke the extension lock.....
abuse? vs just not stout enough? tough call, either way, it was 126 dollar replacement- that was in stock up the street at the vac store (lucky me) UD
Post# 1004675 , Reply# 50   8/24/2018 at 10:06 (2,069 days old) by UncleDave (California)   |   | |
On the twindos front, I'm really surprised I like the system so much. I was very skeptical.
I tried Miele soap before and thought it sucked both in cleaning power and smell - it was a chore even to finish the box. I'm a die-hard Persil fan and was figuring I'd just continue to use my powders I order online and liquid soap I can pick up at Wal Mart. After a few weeks of use I've dialed back the detergent to 18 ML per dose which would give me 83 loads out of a 19 dollar cartridge (if it lets you go away the way to empty) A far cry from the 35-50 loads I've seen quoted I find that's enough for almost everything but the stinkiest toughest loads and I can bump up to a heavy soil which adds a few more CC's (pretty sure) to the load. Loads are coming out clean and a bit whiter - that part is GREAT! I dialed the phase 2 bleach cartridge back to 15 ML per dose giving me an even 100 "white" loads. What's ANNOYING AF is that twindos cartridges simply aren't available or in stock anywhere! Everyone is back ordered from LA to New Jersey and I can't find a thing on amazon. Secondarily the empty user fillable cartridges don't seem to exist in the US- that was part of the program that sold me on the unit. This is one of the biggest problems a manufacturer can have is when they create a system that uses their own consumables - and then can't manage to supply them. Theoretically, I'll get my promotional units today long before I run out - but then what? I'm in a position where I can't get the factory consumables, and I can't use my own consumables as was advertised and shown - what a bummer! I hope Miele gets its act together on this. UD |
Post# 1004679 , Reply# 51   8/24/2018 at 12:31 (2,069 days old) by UncleDave (California)   |   | |
Post# 1004680 , Reply# 52   8/24/2018 at 13:10 (2,069 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
Either order them from abroad yourself or let me know and I could check what I can do for you. |
Post# 1004727 , Reply# 53   8/24/2018 at 22:25 (2,068 days old) by UncleDave (California)   |   | |
Post# 1005338 , Reply# 55   8/29/2018 at 09:13 (2,064 days old) by UncleDave (California)   |   | |
So you had a W1 for 2 years - sent it back and they gave you another older machine.
Do you have write ups/description of your issues someplace over your dissatisfaction I can read? I'd love to see your letter to Miele if you saved a copy. Normally after you own something two years - its yours regardless. It isn't really the years that count in regards to age but the cycles - did any of your machines make it to or past 10K cycles? Curious and thanks! UD |
Post# 1005607 , Reply# 58   8/31/2018 at 14:24 (2,062 days old) by UncleDave (California)   |   | |
Hello Brisnat - I had a few parts fail under warranty and repair was swift, professional - and expensive.
Not being under warranty I didn't bother to bring it up with Mile. It seems to be that they took some solidity out of the machines in the last couple generations. Hello Bewitched, Thanks for the detailed response - I was thinking maybe you already posted this and you could get me a link - vs write the whole thing out but thank you. Interesting -on aggressive factor/lint I noticed the ladles on eth W1 machine are more aggressive than my 1215 in height and in profile- that said in delicate and handwash modes the old machine didn't turn the clothes as well and they slipped under the clothes vs lifting and dumping them a lot more. A profile analogy would be roller vs flat tappet cam profile comparison Also interesting news on the dryer- I'm surprised the dryer only turned in one direction (?!??!?) I would expect an overly aggressive filtration system on a heat pump or condenser dryer - couldn't you just have faked the washing part and reinstalled dry after cleaning the 2 outer filters? As for the shaking that's an interesting problem -mine spins out like a turbine - better than my older unit even on top of an even taller pedestal. Did you by any chance get a vid of this machine doing the shakes? UD |
Post# 1005727 , Reply# 60   9/1/2018 at 09:09 (2,061 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
I have never seen any advantage in having a dryer reverse tumble, in every case in the US at least the few dryers that did reverse were always poorer performers compared to the great dryers that did not reverse.
If a dryer just tumbles in one direction it can have a better tumbling and air-flow pattern as evidenced in the best most produced dryer in the world, the 29" wide top filter Whirlpool built machines. John L. |
Post# 1005751 , Reply# 61   9/1/2018 at 12:10 (2,061 days old) by UncleDave (California)   |   | |
Ostensibly the reason is so that large items dont fold into a ball leaving the center wet. Seems to work "pretty well" for my T1405. for certain none of my old American gas dryers reversed and most did a pretty good job at drying. - but I wonder who has actually tested this. I wonder why Miele ever bothered if the data shows it doesn't help? It's unlike the Germans to add complexity based on a guess- but it happens and they seem to have either changed their minds or decided it wasn't worth the cost - which doesn't mean it isn't a bit better. Volume and popularity is no guarantee of performance and often more closely related to price: The Toyota Corolla is the best selling car in the world - does that make it the best car? UD |
Post# 1005778 , Reply# 63   9/1/2018 at 16:00 (2,061 days old) by UncleDave (California)   |   | |
Interesting find - pretty succinct. I doubt Unimac has this wrong.
proof would be founded upon multiple accurate data points - so far this is the 2nd 3rd party data point I've seen that backs your (and increasingly my own ) opinion on the subject. The first being Miele bothered to put it into some models. My 1405 rotates in fairly equal fashion on normal- on full load it rotates longer in one direction than the other - it still reverses but not as often. UD |
Post# 1005779 , Reply# 64   9/1/2018 at 16:20 (2,061 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
BSH did, ELux does, WP does, Gorenje does and Arcrelik does. So... Yeah. |
Post# 1005791 , Reply# 66   9/1/2018 at 17:32 (2,061 days old) by UncleDave (California)   |   | |
On another note, the cavalry arrived in the form of the twindos promo units.
Oddly shipped at two separate times. The 2 I bought are trailing behind the free stuff. First ones are about 60% full after one month at 18 and 15 MM settings. Didn't count loads but that would be a nice feature to easily see the cycles. I do have a kill-a-watt on it and last I looked the run cost was expected to be about 65 dollars a year. UD
Post# 1006394 , Reply# 69   9/7/2018 at 15:55 (2,055 days old) by UncleDave (California)   |   | |
My toughest recurring load - 6-7 area rugs one being 5X2 and quite plush and absorbs lots of water
This would stymie my 1215 50% of the time and I'm at 5 for 5 on full spin outs with eth W1. I've also run this load with another area mat for the back shower- it was flawless. The background rattle came after the pedestals- the machines a vault. (yeah that's a squatty potty) |
Post# 1006561 , Reply# 71   9/9/2018 at 09:47 (2,053 days old) by UncleDave (California)   |   | |
Not really any advice per se (I don't know enough after a 6 weeks or so to give any) - but I'd pay attention to the various weight each program is good for - you only have max weight available on a few cycles.
Is suspect your water hardness will have a lot to do with 18/15 ML respectively working well for you- but that setting works great for me. On the wireless setup, I had to use is WPS on an apple requires you to log into airport utility and assign the machine as a printer. Keep us updated on the dryer - and thanks for posting! Uncle Dave |
Post# 1006924 , Reply# 72   9/12/2018 at 11:14 (2,050 days old) by Dbv (Ohio)   |   | |
I put in the promotional order for the 6 month supply of Miele TwinDos on Saturday and they are already being delviered today. That is impressive! 3 business days to deliver. |
Post# 1009485 , Reply# 73   10/3/2018 at 12:25 (2,029 days old) by UncleDave (California)   |   | |
Post# 1009501 , Reply# 74   10/3/2018 at 14:49 (2,029 days old) by jerrod6 (Southeastern Pennsylvania)   |   | |
If 10% was left, it is probably asking for the refill early so you have time to order it and get it delivered. I would check it and then keep trying to use it until I got as much as I could. |
Post# 1009589 , Reply# 75   10/4/2018 at 12:12 (2,028 days old) by UncleDave (California)   |   | |
Post# 1083297 , Reply# 76   7/31/2020 at 16:22 (1,362 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
What do you think of the cotton/normal cycle? how aggressive is the agitation/tumbling speed and action? I'd love to see how it performs. |
Post# 1083545 , Reply# 78   8/2/2020 at 05:49 (1,360 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
It's luck of the draw really.
www.trustpilot.com/review... miele.pissedconsumer.com/review.... www.houzz.com/discussions/393274... |
