Thread Number: 76513
Whirlpool Spin Cycle Noise |
Post# 1003663   8/14/2018 at 11:30 (2,074 days old) by eurekastar (Amarillo, Texas)   |   | |
I installed the neutral drain kit on my LA5500XTWO as suggested in a previous thread. I also installed a new clutch assembly. It works as it should; however, when shifting into spin, it makes a buzzing noise that quickly goes away. That noise wasn't there before. Is this normal? If there's a problem, I suspect it is with the new clutch.
Any thoughts would be appreciated! I uploaded a Youtube video. The cycle is permanent press. It first shifts in to low speed spin, stops, then shifts into high speed spin. The noise is more pronounced on high speed. Thanks for any thoughts! CLICK HERE TO GO TO eurekastar's LINK |
Post# 1003670 , Reply# 1   8/14/2018 at 12:34 (2,074 days old) by DADoES (TX, U.S. of A.)   |   | |
Did you note installation of the clutch band turned the correct way? The nubs on the pads should be oriented down (pic 1), not up (pic 2). Check this video starting at 2:17 for assembly of the clutch components. CLICK HERE TO GO TO DADoES's LINK |
Post# 1003674 , Reply# 2   8/14/2018 at 13:07 (2,074 days old) by eurekastar (Amarillo, Texas)   |   | |
Post# 1003810 , Reply# 3   8/15/2018 at 21:15 (2,072 days old) by eurekastar (Amarillo, Texas)   |   | |
As it turns out, I had the brake cam driver incorrectly installed. I simply wasn't paying careful attention to what I was doing. After that was corrected, it runs like a top. I spent the rest of the evening adjusting the water level switch and doing some detailing.
I began repainting the cabinet last weekend. I'll touch up some uneven spots this weekend and it should be ready to go! This has been a fun learning experience. My thanks to all who have given tips, advice, and direction! |
