Thread Number: 7689
looking for a good trans |
Post# 149477   8/20/2006 at 18:35 (6,451 days old) by christfr (st louis mo)   |   | |
Post# 149479 , Reply# 1   8/20/2006 at 18:42 (6,451 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 149532 , Reply# 2   8/20/2006 at 21:51 (6,451 days old) by gregm ()   |   | |
tell me this is NOT like the one you sent home with me, LOL |
Post# 149546 , Reply# 3   8/20/2006 at 22:41 (6,451 days old) by fixerman ()   |   | |
Why not rebuild it. They are relatively easy to do. Old maytags are prone to this problem so the next one could start leaking in short order. |
Post# 149721 , Reply# 4   8/21/2006 at 17:48 (6,450 days old) by christfr (st louis mo)   |   | |
how rough is it to replace the seal in the bottom i had thought i was a real bear? this machine has given me one fit after another..when i got the washer the tub nut had broken off so to do that job the agi had to come out but it was stuck so like a fool i took a hammer and broke it off and in doing so i damaged something inside the trans and locked it up. then i got a used trans from greg m from a late 60s early 70s machine but i didnt notice that that trans way about 1/4 inch longer. when i installed that trans the machine would get stuck when it tried to spin so i thought i had a clutch prob.. got a clutch but it did the same thing. but then i got a whole machine from greg and just took all the best parts from both to make one good machine and in doing so i could see the orig trans was about a 1/4 inch shorter than the late 60s early 70s machine.. but once i put the same length trans in there all was fine till this weekend and she sprung a leak. should i just go for a seal?? does the whole trans have to comeout again?
Post# 149736 , Reply# 5   8/21/2006 at 18:14 (6,450 days old) by gregm ()   |   | |
the trans you got from me was from a '62 |
Post# 149785 , Reply# 6   8/21/2006 at 21:55 (6,450 days old) by mayken4now (Panama City, Florida)   |   | |
Post# 149839 , Reply# 7   8/22/2006 at 06:34 (6,450 days old) by christfr (st louis mo)   |   | |
oh steve i already have a bad bad rollermatic here ha ha that child wants lots of attention. i always said they have minds oh their own.. then the multimatic needs to be cracked open again and the 1-18 is gettin really noisy and now the tag is pissed off. il give the tag a try it cant hurt to try, since i have the match dryer i cant give up just yet.. and then the rollermaitc will just have to wait til i find a good support but im trying....so steve dont give up just yet honestly your almost there with that machine just park it till mr andrews gets back over. trust me once its done you really like playing with that machine..hang in there
Post# 149846 , Reply# 8   8/22/2006 at 07:20 (6,450 days old) by mayken4now (Panama City, Florida)   |   | |
Post# 149853 , Reply# 9   8/22/2006 at 08:03 (6,450 days old) by gregm ()   |   | |
yes, steve you are nuts (wink, hehehe) |
Post# 149878 , Reply# 10   8/22/2006 at 12:13 (6,450 days old) by christfr (st louis mo)   |   | |
