Thread Number: 7940
Miele w 1215 |
Post# 152750   9/6/2006 at 07:08 (6,440 days old) by sudsman ()   |   | |
Can anyone tell me what the rated capacity is on the 1215 Washer ? |
Post# 152776 , Reply# 1   9/6/2006 at 09:37 (6,440 days old) by westtexman (Lubbock, Texas)   |   | |
That the 1215 has a 6KG capacity. I'm not sure what that translates into as far as cubic feet. Bryan |
Post# 152793 , Reply# 2   9/6/2006 at 12:15 (6,440 days old) by sudsman ()   |   | |
6 kg is around 12 lbs I cant find the rating anywhere that I have looked |
Post# 152859 , Reply# 4   9/6/2006 at 19:01 (6,439 days old) by sudsman ()   |   | |
What is the model of the 6 kilo you have??? |
Post# 152951 , Reply# 5   9/7/2006 at 08:11 (6,439 days old) by lavamat_jon (UK)   |   | |
My mum has a W3922WPS, which is a UK 6kilo model - however the US 6kilo machines are even larger than my mum's so I would suppose it has more than ample capacity. Jon |
Post# 153060 , Reply# 8   9/7/2006 at 16:13 (6,439 days old) by westtexman (Lubbock, Texas)   |   | |
Ah, cool. Thanks for the clarification. I guess that's one of the VERY FEW advantages the US Mieles have over the UK ones. I guess that extra 4 litres of H2O is supposed to make up for the fact that our machines are so dumbed down here? LOL. |
Post# 153871 , Reply# 10   9/12/2006 at 03:37 (6,434 days old) by launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Consumer Reports did a test several years back and came to the conclusion that most washing machines perform best if loaded slightly under the stated capacity. Weight is not a very good indicator of laundry loads for a start. Just three or maybe four hyge,thick and thirsty towels is pretty much what my 5KG Miele will take before it lets me know it is not happy. Then again my unit is an older model and uses lots of water for both washing and rinsing. If the unit loaded too much with heavy items, one can hear the tub scuffing the bottom of the washer as the load bounces around. Thankfully Miele's have good suspension systems. Problem with top loaders is that unless well designed, over loading will cause the washing action to come to a stand still, with items near the agitator taking a pounding, while there is little or no roll over to bring everything else into action. L. |
Post# 153873 , Reply# 11   9/12/2006 at 03:59 (6,434 days old) by irishwashguy (Salem,Oregon.............A Capital City)   |   | |
i wash alot of loads that I do fill it up.More so that the Maytag Neptune 4000 that would choke on blankets.I love the honey comb drum in the Miele, and it has a built in heater.I only have it hooked to the cold water so all water is heated to the exact temp that i set. i even reduced the amout of soap that I use in it from my old machine, it is very efficient. This is my two cents.
