Thread Number: 81
Need timer info |
Post# 45080 , Reply# 1   9/14/2004 at 12:06 (7,155 days old) by coldspot66 (Plymouth, Mass)   |   | |
The timer motors today are usually not replaceable as a seperate item. If you can give me the model number, serial number I could find out for you. |
Post# 45082 , Reply# 2   9/14/2004 at 12:15 (7,155 days old) by coldspot ()   |   | |
the # on the timer is. rspc 31239 also a nm#145-699-12 the # on the motor it selg is. 414-371-20 Washing maching is amana model lw6501w2 with plant # plw6501w2b Thanks so so much Troy |
Post# 45090 , Reply# 3   9/14/2004 at 13:58 (7,155 days old) by coldspot66 (Plymouth, Mass)   |   | |
The timer motor is not a replaceable item; you have to replace the whole timer. Do you have a parts dealer that you can go to? john |
