Thread Number: 8347
Kitchen Aid Dishwasher, please help. |
Post# 158600   10/3/2006 at 17:02 (6,386 days old) by volvoguy87 (Cincinnati, OH)   |   | |
One of my friends has a Kitchen Aid dishwasher model KDC-17A. Does anyone know anything about this machine? I am curious to know when it was in production and where it stood in the model-lineup at the time. It is also experiencing some trouble. It stopped during the cycle, possibly during the rinse, and it is still full of water. When she tries to re-start the machine, it clicks, but nothing happens. Is this a timer issue? A motor issue? Some type of drain valve, or pump issue? The circuit breaker for the dishwasher has not tripped. If it is not feasable to repair this problem, the dishwasher may be available. Any advice would be much appreciated. Thanks to everyone in good appliance land, Dave |
Post# 158624 , Reply# 2   10/3/2006 at 20:42 (6,386 days old) by bajaespuma (Connecticut)   |   | |
We owned a KDC-17a. I just sent out a couple of repair masters to a couple of members on this site, I'm hoping one of them is going to scan it and submit it for the Manuals section on the site. IIRC, those models didn't use a float valve for the drain. They used an internal pressure switch like a clothes washer. That may be your problem. I'll take a look in the manual to see if I can find anything else. |
Post# 158633 , Reply# 3   10/3/2006 at 21:03 (6,386 days old) by dadoes (TX, U.S. of A.)   |   | |
Fill is timed. The pressure switch is protection against overflow, and is not involved in draining. There is a solenoid-operated drain valve. The motor does not reverse for drain, the valve simply opens to let the water flow through. In fact, the motor runs continuously through the entire wash/rinse part of the cycle, shutting of only after the last drain before the drying phase begins. A bad drain valve/solenoid would not make the machine stop running, it would just keep circulating through the entire cycle and never drain. The 17 series ran during the early to mid 1970s. The 17a series was the first to have a no-heat dry option. As mentioned above, KDC-17a is the Custom model, which is the lower-end machine with Full Cycle and Rinse/Hold. |
