Thread Number: 855
Re: Whirlpool Compact Stackable Washer/Dryer at Lowe's: |
Post# 51971 , Reply# 1   12/28/2004 at 23:29 (7,057 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 51979 , Reply# 2   12/29/2004 at 03:21 (7,057 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
I downloaded the manual (for the washer, the one for the dryer is not yet available). I noticed some things. On the website Whirlpool says it has 5 temperature settings, but the temperature settings are integrated in the cycles. I can only see three temperatures in the manual, hot, warm and cold. There are no delicate cycles. There is however a Handwash cycle, but that only has a warm temperature setting, like the Quickwash cycle. No cold for woolens and other delicate stuff. The website tells us that it has an internal water heater, no mention of that in the manual and IIRC discussions about this machine it doesn't have one. This washer has no heating element, but it also doesn't have a bleach dispenser. You are supposed to clean this washer out with chlorine bleach, yet you can't use it on your whites. It has a lint filter, not a button trap. Most modern European washers have a self cleaning lint filter that doesn't need cleaning. This washer has a filter that apparently needs to be cleaned every month. The capacity is rather big, it's rated 2.9 cu ft. which is the same as the Maytag Neptune frontloader. There is a pedestal available. |
Post# 51988 , Reply# 3   12/29/2004 at 09:28 (7,056 days old) by christd1 ()   |   | |
These are not 2.9 cu. ft. DOE capacity but 2.9 IEC rating. These are smaller than both the neptune and the FriGEmores. |
Post# 52161 , Reply# 4   12/31/2069 at 18:00 (19,838 days old) by kenmore1978 ()   |   | |
They certainly don't sound very flexible. |
