Thread Number: 8696
pulling inner tub from multi-matic |
Post# 163334 , Reply# 1   10/27/2006 at 23:10 (6,389 days old) by rickr (.)   |   | |
I have a 61 Multi-Tragic that will be used for parts sometime next summer. If the outer tub is ok, you are welcome to it Greg. Had a 1963 model in the 1980's and I did figure out how to tear it down. Cannot remember much about doing it now however. Was not able to obtain replacement transmition parts for it, so it went to the scrapper "torn down". |
Post# 163349 , Reply# 2   10/28/2006 at 01:23 (6,389 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Got your email late tonight and here you are on the forum! You should make sure the face of the carbon seal and the bronze ring on the underside of the hub (tub mounting) is clean and free of dirt, water, grease, etc. Put a thin film of light turbine oil on the carbon seal face and you're good to go... |
