Thread Number: 9012
Naco Home Laundry - Model 5 |
Post# 168534 , Reply# 1   11/19/2006 at 03:18 (6,361 days old) by brisnat81 (Brisbane Australia)   |   | |
This is the control knob in the wash position. Moving the lever shifts the motor and a tension pulley and transfers power between 1 of 2 belts. |
Post# 168536 , Reply# 3   11/19/2006 at 03:43 (6,361 days old) by brisnat81 (Brisbane Australia)   |   | |
This is the view with the red lid removed, down the chute into the wash basket. This machine is pretty much the same as the first machine my grandmother had, when she replaced the copper. |
Post# 168538 , Reply# 5   11/19/2006 at 03:50 (6,361 days old) by panthera (Rocky Mountains)   |   | |
I wonder about the spin, tho'...if you get the chance, could you post some shots of her innards... I have never seen anything similar. Looks like a serious attempt at simplest solution possible to each difficult task. Leather? Whow! I had to replace a leather sewing machine belt not too long ago for a nonogenarian friend. I cheated and wet it...still working, so guess that was not too bad. How do you replace and tension them correctly (I assume the load on this machines belt is a bit higher than the peddle sewing machine.) |
Post# 168539 , Reply# 6   11/19/2006 at 03:52 (6,361 days old) by brisnat81 (Brisbane Australia)   |   | |
Behind the right access panel is an overload switch. Its rated at 3.5 amps 240v, and is rusted solid and full of old wasps nests. The supply cord is totally perished also, so I'll take the whole assembley to an elextrician and have it tested/rewired. |
Post# 168540 , Reply# 7   11/19/2006 at 03:54 (6,361 days old) by brisnat81 (Brisbane Australia)   |   | |
The drain hose is connected directly to the bottom of the outer tub. There is then a flexible hose that goes through a clamp of sorts, and by rotating the knob on the bottom left of the machine, you either clamp or unclamp the drainhose allowing the water to run out. |
Post# 168541 , Reply# 8   11/19/2006 at 03:57 (6,361 days old) by brisnat81 (Brisbane Australia)   |   | |
Other than the motor, those pulleys at the back is as complicated as it gets. When I remove the belts, I'll take the tub pulley off to see what sort of bearing is in place. |
Post# 168542 , Reply# 9   11/19/2006 at 03:59 (6,361 days old) by brisnat81 (Brisbane Australia)   |   | |
Post# 168543 , Reply# 10   11/19/2006 at 04:05 (6,361 days old) by brisnat81 (Brisbane Australia)   |   | |
Post# 168544 , Reply# 11   11/19/2006 at 04:10 (6,361 days old) by brisnat81 (Brisbane Australia)   |   | |
Post# 168545 , Reply# 12   11/19/2006 at 04:12 (6,361 days old) by brisnat81 (Brisbane Australia)   |   | |
Post# 168546 , Reply# 13   11/19/2006 at 04:15 (6,361 days old) by panthera (Rocky Mountains)   |   | |
Post# 168557 , Reply# 14   11/19/2006 at 04:54 (6,361 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 168563 , Reply# 15   11/19/2006 at 05:48 (6,361 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Wow, another great find, no sleep for you two tonight!!! That Naco logo looks very "Hooveresque", look like a cross between a Bendix for innards and performance, ie.e bolt down etc and a mini sloping Westinghouse, and the best bit with the shute it does away with the traditional door seal, wont take much to have a spa bath & paint job to get this beauty pristine again.... My guess is the spin will be 460 rpm... and a good 10lb load not bad.. Enjoy, Mike |
Post# 168586 , Reply# 17   11/19/2006 at 10:07 (6,361 days old) by unimatic1140 (Minneapolis)   |   | |
Post# 168597 , Reply# 18   11/19/2006 at 10:41 (6,361 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 168705 , Reply# 20   11/19/2006 at 21:53 (6,361 days old) by westytoploader ()   |   | |
Nathan, congratulations! That chute is super-cool, what an ingenious idea. Good luck on getting it up and running! |
Post# 168771 , Reply# 21   11/20/2006 at 13:35 (6,360 days old) by christfr (st louis mo)   |   | |
