Thread Number: 9071
kitchenaid help please |
Post# 169385   11/23/2006 at 19:49 (6,360 days old) by christfr (st louis mo)   |   | |
well i found this ka dw for 25 bucks on craigslist last year and the lady said it didnt wash well any more.. so got it home and the pump was clogged with cat hair.. it then ran just fine so i put her in the house.. was wonderfull till about 3 weeks ago.. i thought it was a timer prob installed a new timer but she still has a mind of her own.. i need some ideas of what to tinker with next... mod # KUDJ230YWH3.. these probs are off and on again so im not sure... when you start the machine it will either be fine or it will only fill 1/4 full and try to wash or she will sometimes fill then drain then fill then drain over and over till you reset the timer..or sometimes its like the heat booster will get stuck and it will run for an hour and the timer wont advance and the water is like boiling in there.. now i did notice that the push button switches feel funny and i you jiggle them while its running the machine sometimes wants to cut out and stop running?? any ideas
Post# 169386 , Reply# 1   11/23/2006 at 19:51 (6,360 days old) by westytoploader ()   |   | |
The pump was clogged with CAT HAIR? Oh lawd...you have to wonder what she was putting in there! |
Post# 169450 , Reply# 2   11/24/2006 at 00:12 (6,360 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 169473 , Reply# 3   11/24/2006 at 04:49 (6,359 days old) by mikepaquette ()   |   | |
Go For the Westinghouse. Very nice dishwasher. Mike |
Post# 169480 , Reply# 4   11/24/2006 at 07:12 (6,359 days old) by gyrafoam (Wytheville, VA)   |   | |
Maybe the timer is still the problem. A defective re-build maybe? Sounds like bad contacts somewhere. |
Post# 169488 , Reply# 5   11/24/2006 at 07:53 (6,359 days old) by christfr (st louis mo)   |   | |
Post# 169919 , Reply# 7   11/26/2006 at 21:58 (6,357 days old) by appnut (TX)   |   | |
Post# 169968 , Reply# 8   11/27/2006 at 06:12 (6,356 days old) by christfr (st louis mo)   |   | |
ha ha i have a club for the car?? this dw has a reg timer and a set of switches.. i put in a new timer and im gonna put a new set of switches in there next to see if thats it.. then again it could be several probs all at once.. where is the temp sensor located? wonder if that thing is getting stuck too
Post# 169971 , Reply# 9   11/27/2006 at 06:31 (6,356 days old) by tomturbomatic (Beltsville, MD)   |   | |
Maybe cat hair has gathered under the float and does not let it return to the fully down position so when it fills, the float rises before the tank is filled, shutting off the water, maybe? |
Post# 170516 , Reply# 10   11/29/2006 at 15:42 (6,354 days old) by toggleswitch (New York City, NY)   |   | |
Post# 170517 , Reply# 11   11/29/2006 at 15:57 (6,354 days old) by chachp (North Little Rock, AR)   |   | |
Post# 170518 , Reply# 12   11/29/2006 at 15:57 (6,354 days old) by maytagbear (N.E. Ohio)   |   | |
Cats are like the best ovens--- They are both self-cleaning! However, never try to clean a cat in an oven. Would not be good for either the cat or the oven. ^_^ Lawrence/Maytagear |
Post# 170532 , Reply# 13   11/29/2006 at 17:39 (6,354 days old) by christfr (st louis mo)   |   | |
