Thread Number: 925
Frigidaire Washer Suspension Problem |
Post# 52676 , Reply# 1   1/6/2005 at 17:02 (7,041 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Sounds like a broken spring or shock absorber. You can remove the top panel, there should be screws at the back of the machine (2 sets) and the panel should slide back and lift off. You can also remove the bottom access panel in front - remove two screws near the floor and pull the panel out toward you. Check the springs at the top on either side of the tub and the shock absorbers at the bottom. |
Post# 52677 , Reply# 2   1/6/2005 at 17:11 (7,041 days old) by Charlie1 ()   |   | |
Awesome diagnostics, gansky1! Not to mention FAST! It's a busted shock absorber, the ring around where it attaches to the frame has snapped. Looks easy enough to replace. Thanks for the help! |
Post# 52684 , Reply# 4   1/6/2005 at 18:10 (7,041 days old) by partscounterman (Cortez, Colorado)   |   | |
part #131268200 |
Post# 52692 , Reply# 6   1/6/2005 at 20:51 (7,041 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Sears.com has lots of parts diagrams for many different models. You should be able to find what you need there. I would definitely compare prices, there can be a big difference from one internet site to another...
CLICK HERE TO GO TO gansky1's LINK |
