Thread Number: 9319
GE Pair -- Free Local Pick-Up |
Post# 173170   12/6/2006 at 21:56 (6,321 days old) by dadoes (TX, U.S. of A.)   |   | |
Giver-awayer says both run. Washer has a tub leak (apparently minor enough to still use the machine), doesn't stop spinning when lid is opened, and sometimes doesn't spin very well on low speed. Dryer squeals, assume bad bearings or drum glides. Washer front is ajar from her husband having a look for the leak. Opinions as to whether they're worth saving/fixing? |
Post# 173187 , Reply# 1   12/6/2006 at 22:24 (6,321 days old) by mayken4now (Panama City, Florida)   |   | |
Post# 173190 , Reply# 2   12/6/2006 at 22:26 (6,321 days old) by appnut (TX)   |   | |
Post# 173192 , Reply# 3   12/6/2006 at 22:39 (6,321 days old) by exploder321 ()   |   | |
Trash |
Post# 173193 , Reply# 4   12/6/2006 at 22:39 (6,321 days old) by westytoploader ()   |   | |
EEEEEEEK! POS!!!! |
Post# 173212 , Reply# 5   12/6/2006 at 23:26 (6,321 days old) by dadoes (TX, U.S. of A.)   |   | |
Awwww, not even for fun? For free? (other than a bit of gas to fetch them) Hey, I paid $135 for a 5- to 6 year-old Calypso which seems to be doing OK (uhhh, after replacing the motor controller board, LOL). Rebuilt the free Neppy dryer (which came from the same area). Seems I do better with "modern" stuff than vintage. The 906 & WO-65 may be lost causes. :-( |
Post# 173213 , Reply# 6   12/6/2006 at 23:30 (6,321 days old) by tbolt25 (Kentucky)   |   | |
Junk! Junk! Junk! Plastic! Plastic! Plastic! I say get rid of that plastic GE crap! |
Post# 173235 , Reply# 9   12/7/2006 at 01:33 (6,321 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
If there are problems with spinning and a "small" leak, it's probably coming from the main seal and the machine isn't worth the two hours of back-breaking work to get the tub out and IF the tranny seal is still intact, you'll only have to replace the tub seal. Out of the many, many machines I've picked up, worked on and resold, I can remember only a scant handful of these plastic GE's.
Post# 173242 , Reply# 10   12/7/2006 at 02:14 (6,321 days old) by dadoes (TX, U.S. of A.)   |   | |
Post# 173300 , Reply# 11   12/7/2006 at 09:33 (6,320 days old) by rp2813 (Sannazay)   |   | |
Post# 173361 , Reply# 12   12/7/2006 at 12:28 (6,320 days old) by dadoes (TX, U.S. of A.)   |   | |
Post# 173443 , Reply# 13   12/7/2006 at 16:27 (6,320 days old) by dadoes (TX, U.S. of A.)   |   | |
Post# 173608 , Reply# 15   12/7/2006 at 23:30 (6,320 days old) by dadoes (TX, U.S. of A.)   |   | |
Whelp, it's true, they're kinda icky, LOL. Not specifically because of being Plastic GE, but because they're .... kinda icky/dirty. The dryer door liner is worn down to bare metal on one side. Don't figure how that happened. Musta been rode pretty hard. Haven't yet run it to check the squeal. The washer is dirty (basket, softener cup, agitator). There's a ring of hard water deposits around the top of the basket (scrapes off with a fingernail). Appears somebody sat on the lid and smushed it from convex to concave, but I popped it back (or is it supposed to be *flat*?). The agitator is kinda loose (the entire base, not just the auger). It does run and the lid switch seems OK so I don't know what she meant about spin not stopping when the lid is opened. Lack of spin on slow speed appears to be a belt problem, loose or worn (or maybe slick from the water leak or an oil leak??). The motor runs but not enough pull to get it spinning on low speed. It reaches full speed OK on high. Interesting ... the lid switch stops the main drive motor during spin but the pump motor keeps running. |
Post# 173615 , Reply# 16   12/7/2006 at 23:50 (6,320 days old) by exploder321 ()   |   | |
Curious if they are easy fixes |
Post# 173621 , Reply# 17   12/8/2006 at 00:09 (6,320 days old) by appnut (TX)   |   | |
Post# 173634 , Reply# 18   12/8/2006 at 01:58 (6,320 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
GE used a die-cast aluminum hub and tub nut which corrode and make it all but a lost cause to remove in many cases. (the hard water ring in the basket doesn't sound good for what's coming under that agitator) The agitator hub is a plastic "cup" bolted to the low-post agitator shaft and the agitator is snapped down onto that cup. You should be able to yank on the agitator base and remove it fairly easily. (Famous last words!) then you'll be able to see how it's assembled underneath. You should be able to see evidence of the water leak under the tub - follow the "trail" back to it's origin. If there's any evidence of oil spraying around under the tub, run screaming away from this washer, it's done for. The difference in the GE construction and Maytag's is that Maytag utilized an air bubble under the agitator to keep water away from the agitator shaft and seals. GE doesn't do this so those parts are more prone to corrosion. Planned obsolecence. |
Post# 173641 , Reply# 19   12/8/2006 at 03:12 (6,319 days old) by dadoes (TX, U.S. of A.)   |   | |
I took a spin through Sears Parts tonight, looked at the diagrams. Tub seal/bearing, basket hub/nut, agitator cup. Does look to be design/construction of questionable quality. Some of the parts aren't expensive (bearing, seals, nut), some are (tranny, clutch, ATC board). The giver-awayer didn't mention any oil spray and they did pull the front panel to look for the water leak. Of course, they maybe just didn't mention it. I haven't yet looked under the skirt. It may very well be headed for the Krusher. The dryer could be salvageable, but also perhaps not worth the effort. It's thermostat auto-dry. Possibly a few spare parts for the F&P DE04, possibly not!
Post# 173747 , Reply# 21   12/8/2006 at 15:20 (6,319 days old) by dadoes (TX, U.S. of A.)   |   | |
It's the inside panel of the dryer door that's worn bare. Maybe they were drying suits of chainmail. The drum support, dunno yet. I turned the drum by hand a bit, didn't hear anything alarming. The washer brake seems OK. A full spin brakes quickly, if that means anything. The tub is very loose, kinda like an F&P :-) I'm thinking it probably shouldn't be *that* loose. Haven't yet connected it to water, maybe this weekend. |
Post# 173758 , Reply# 22   12/8/2006 at 16:26 (6,319 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 173766 , Reply# 24   12/8/2006 at 16:54 (6,319 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
The tub/tranny/motor assembly is suspended from springs & rods, just like the F&P so it will move around quite a bit. GE added rubber bands to arrest some of the sway and back-and-forth movement, but as Austin said, they have a tendency to break. I've seen lots of dryer doors - from all brands - that the powdercoating is worn away, alas - porcelain is no more! |
Post# 174168 , Reply# 25   12/9/2006 at 18:22 (6,318 days old) by goatfarmer (South Bend, home of Champions)   |   | |
The dryer is probably an easy fix. Most times,a plastic front drum support,and 4 glides is probably all that's wrong with it. About a half hour or so to fix. When that style GE washer first came out,someone familiar with them told our technician,that if the center seal leaked,occasionally you had to replace the whole transmission,because of the shaft being undersize with regard to the seal,and a new seal alone wouldn't stop the leak. You paid the right price for them. kennyGF |
Post# 174173 , Reply# 26   12/9/2006 at 18:28 (6,318 days old) by paulg (My sweet home... Chicago)   |   | |
I also had parents that bought that same series of washer. It lost its tranny before 5 years went up. Couldn't find the receipt so it went to the junker. Barely used. The deliveryman for the (post-GE) new washer said "You're throwing this GE washer away? Isn't this GE washer NEW??? " I advised that it was 4 and 9/10 years old and junk. CRUSH the washer and never look back.... |
Post# 174182 , Reply# 27   12/9/2006 at 19:17 (6,318 days old) by irishwashguy (Salem,Oregon.............A Capital City)   |   | |
Post# 174205 , Reply# 28   12/9/2006 at 21:23 (6,318 days old) by exploder321 ()   |   | |
Good idea.. Maybe something to "explode" while at the wash in?? |
Post# 174966 , Reply# 29   12/12/2006 at 20:45 (6,315 days old) by exploder321 ()   |   | |
Here's ya a Transmisson For it CLICK HERE TO GO TO exploder321's LINK on eBay |
Post# 174991 , Reply# 30   12/12/2006 at 21:35 (6,315 days old) by vintagesearch ()   |   | |
lol "something to explode at the wash in" let me send you ours when you hear it spin it sounds like the excorcist trying to sing! oh yeah we have a ge too by the way lol! |
Post# 174994 , Reply# 31   12/12/2006 at 21:42 (6,315 days old) by exploder321 ()   |   | |
more fun |
