Thread Number: 9322
Old Maytag set on Seattle craigslist |
Post# 173259   12/7/2006 at 06:57 (6,343 days old) by northwesty (Renton, WA)   |   | |
Here is an old set on Seattle Craigslist. It has been on a few days, don't know how I missed it. $75 for both CLICK HERE TO GO TO northwesty's LINK on Seattle Craigslist |
Post# 173268 , Reply# 1   12/7/2006 at 07:28 (6,343 days old) by appnut (TX)   |   | |
Post# 173277 , Reply# 2   12/7/2006 at 07:57 (6,343 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 173633 , Reply# 4   12/8/2006 at 01:49 (6,342 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
With the '08 series Maytags, the bleach dispenser was moved to the left side, made a larger, triangular shape and was simply a funnel into the outer tub rather than a storage and dillution tank as on earlier models. The dillution process took approximately 5 minutes to be completely dispensed into the wash-water. Oddly, a similar system was used on the Maytag combo but not through the pump as it was only active during drain/spin/dry cycles. There was a hose from the front, left side of the drum into the dispenser and another from the dispenser to the sump under the machine. The tumbling action inside the drum caused a pumping of the water through the hose at the front, pushing the water through the dispenser and into the sump where it was further dilluted in the drum with the water & clothes. |
Post# 173795 , Reply# 5   12/8/2006 at 19:55 (6,341 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
