Thread Number: 9381
Found By a Dumpster... |
Post# 174394 , Reply# 1   12/10/2006 at 15:56 (6,340 days old) by exploder321 ()   |   | |
Sensor Controlled |
Post# 174395 , Reply# 2   12/10/2006 at 15:56 (6,340 days old) by exploder321 ()   |   | |
Heres the controls |
Post# 174396 , Reply# 3   12/10/2006 at 15:57 (6,340 days old) by exploder321 ()   |   | |
Here's the drum..Does need a good cleaning |
Post# 174397 , Reply# 4   12/10/2006 at 15:57 (6,340 days old) by exploder321 ()   |   | |
Here's the seriel plate.. Its a TD 73 |
Post# 174399 , Reply# 6   12/10/2006 at 16:02 (6,340 days old) by easyspindry (Winston-Salem, NC)   |   | |
What a great find!!! Way to go. Jerry Gay |
Post# 174587 , Reply# 8   12/11/2006 at 07:42 (6,339 days old) by toggleswitch (New York City, NY)   |   | |
Yes, as stated above at 15a the wires ARE thinner. Put a dryer plug on it and stick it in a std. 30a 220v dryer outlet and you are OK to go. If you are using a 4 prong plug be sure the ground strap (is there one on this foreign thing?) on the dryer is NOT connected to the neutral terminal conductor. If you ARE using a 3-prong plug /connnector/flex the ground strap SHOULD be connected to the neutral connector. For more detailed info see the installation instructions of any modern US dryer. Techincally 15a wire on a 30a cicuit does not afford one the level of fire protection we are used to. But I dont see this as a problem. After all in a US dryer not all wires within the machine can handle 30a, IIRC. |
Post# 174596 , Reply# 9   12/11/2006 at 09:00 (6,339 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 174948 , Reply# 10   12/12/2006 at 19:37 (6,338 days old) by gocartwasher ()   |   | |
nice find |
Post# 174954 , Reply# 11   12/12/2006 at 19:54 (6,338 days old) by laundromat (Hilo, Hawaii)   |   | |
Post# 174959 , Reply# 12   12/12/2006 at 20:00 (6,338 days old) by laundromat (Hilo, Hawaii)   |   | |
One of the first things you'll want to check w/out power is be sure the pin that is located on the right side of the inner part of the door which is the door switch is not broken off.If it is,you will need to replace the entire inner door frame or force a screw into the engaging switch to make it stay on permanently.This happens a lot because the owners are too stupid to close the dryer door without slamming.Because of the door seal being a strong magnet,slamming the door doesn't close it any better or faster than just pushing in.
