Thread Number: 9485
w0-65 ching ching |
Post# 176018   12/16/2006 at 13:48 (6,311 days old) by christfr (st louis mo)   |   | |
Post# 176682 , Reply# 1   12/19/2006 at 13:18 (6,308 days old) by toggleswitch (New York City, NY)   |   | |
Post# 176735 , Reply# 3   12/19/2006 at 17:07 (6,308 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Chris - have you ever had the pump cover off? It sounds like you might just have a loose pump screw - common with unimatics. Lay the machine in it's left side (so you don't pee oil out of the vent tube on the tranny), remove the cross-brace, support the mechanism (a gallon paint can works well) and remove the pump cover screws. Once you have removed the cover, you can see the bottom of the pump impeller and a slot-head screw in the center. This screw holds the pump impeller and the fan in place on the motor shaft - the impeller has a long "neck" that extends through the pump seal and cover and compresses against the fan to hold it tight. Remove the pump screw with a large screwdriver so as not to strip the head and put a few drops of Loctite on the threads. The pump impeller should be seated far enough up onto the fan to hold it tight.
Post# 176752 , Reply# 4   12/19/2006 at 19:26 (6,308 days old) by christfr (st louis mo)   |   | |
oh i see toggle got bossy ha ha.. when i got the machine and first ran it it sounded like it does now like a ting ting ching ching noise and i could feel the fan was loose thats when i took the pump apart and off and at that time i tried to ship the fan and the spline of the motor and it worked for a little while but didnt last i think i used some sealer or something.. didnt try lock tite hum will have to take it apart again and check it out but thanks guys for the info as always steve and greg as so sweet and togg is being bossy ha ha xxxx
Post# 176756 , Reply# 5   12/19/2006 at 19:58 (6,308 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 176892 , Reply# 6   12/20/2006 at 06:12 (6,307 days old) by christfr (st louis mo)   |   | |
Post# 177173 , Reply# 7   12/21/2006 at 15:47 (6,306 days old) by toggleswitch (New York City, NY)   |   | |
HA! In the business world I'm results-oriented. Here I'm just a bossy bitch. That's OK Christopher I STILL hold you in high regard and esteem. *LOL* Calls mother: Hello mother? THAT BRUTE. I gave him just what he wanted, bumped up his post, made sure he was not ignored, got him an answer and STILL he tossed me to the wolves. *BOO HOO SOB MOAN* OK I'm over it, NEXT............ |
Post# 177362 , Reply# 8   12/22/2006 at 06:17 (6,305 days old) by christfr (st louis mo)   |   | |
Post# 177371 , Reply# 9   12/22/2006 at 08:16 (6,305 days old) by toggleswitch (New York City, NY)   |   | |
Post# 177372 , Reply# 10   12/22/2006 at 08:17 (6,305 days old) by toggleswitch (New York City, NY)   |   | |
Post# 177557 , Reply# 11   12/23/2006 at 10:14 (6,304 days old) by unimatic1140 (Minneapolis)   |   | |
Yes these fans do not wear out and I've never needed new one. The problem as Greg stated above is the pump impeller screw has to be extremely tight. Over the years it has loosened. Be sure to take the screw completely out and add some blue Loctite to the threads. Tightening the impeller screw will not break the carbon seal unless it is not seated properly, so make sure the four tangs off of the carbon seal are seated properly in the four channels in the center of the impeller. |
Post# 177976 , Reply# 12   12/24/2006 at 19:10 (6,303 days old) by sudsmaster (SF Bay Area, California)   |   | |
Post# 178020 , Reply# 13   12/25/2006 at 00:06 (6,303 days old) by exploder3211 ()   |   | |
I think it's cause all of our screws are a little loose Chad (formerly exploder321) |
Post# 178064 , Reply# 14   12/25/2006 at 11:25 (6,302 days old) by christfr (st louis mo)   |   | |
Post# 178236 , Reply# 15   12/26/2006 at 12:43 (6,301 days old) by toggleswitch (New York City, NY)   |   | |
