Thread Number: 9829
Maytag A606 Leaking Again :( |
Post# 181591 , Reply# 3   1/8/2007 at 11:22 (6,289 days old) by danemodsandy (The Bramford, Apt. 7-E)   |   | |
Julia: Check out this thread, being sure to allow time for the pictures to download, and see if it has any bearing on your washer's problem: www.automaticwasher.org/TD/THREAD... If it does, you're in luck; this is an easy, cheap repair. |
Post# 181631 , Reply# 6   1/8/2007 at 16:11 (6,289 days old) by toggleswitch (New York City, NY)   |   | |
Post# 181644 , Reply# 7   1/8/2007 at 17:14 (6,289 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 181699 , Reply# 8   1/8/2007 at 20:23 (6,289 days old) by sudsmaster (SF Bay Area, California)   |   | |
Post# 181725 , Reply# 9   1/8/2007 at 21:15 (6,289 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 181930 , Reply# 12   1/9/2007 at 17:15 (6,288 days old) by goatfarmer (South Bend, home of Champions)   |   | |
"Oddly enough, there is a little thingamajig on the right hand side on the floor of the machine...I suppose it contains some electrical elements or something, perhaps. It has a white-ish plastic cover on it. In the diagram I have, it is called a "reversible self-cleaning poly pump". Fancy name. ;) " Not too odd,that's the pump,runs off a belt from the motor,nothing electrical involved.Shouldn't be any moisture there.Fix the first problem,then wipe off the pump thoroughly,and run a few cycles to see if the pump is indeed leaking. If you're not familiar with taking one of those fill assemblys apart,I would change the whole thing. kennyGF |
Post# 182083 , Reply# 13   1/9/2007 at 22:44 (6,288 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
nozzle and tube kit 400646-this consists of black rubber air gap kit 444984 and fill injector nozzle 3259 hose inlet to injector 1798 injector tube sleeve bracket 1529 injector hose located at top of tub cover 435487 numbers are repairclinic order # Actually there is at the back of my A606s on the right rear there is a box with wires that is the suds saver valve the pump sits in front of it |
Post# 182084 , Reply# 14   1/9/2007 at 22:45 (6,288 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 182339 , Reply# 15   1/10/2007 at 19:55 (6,287 days old) by westyslantfront ()   |   | |
Hi Julia. Welcome to the club and greetings from Tucson, Arizona. Sure wish you luck on getting your machine fixed. Those are great machines. Ross |
Post# 182548 , Reply# 18   1/11/2007 at 16:47 (6,286 days old) by panthera (Rocky Mountains)   |   | |
Just feel free to keep asking questions. And don't worry if we tend to drift in and off topic. I am not a Maytag expert (and our winter storms make me kinda of an on again and off again logger right at the moment) but I, too, have had that funny water-where-none-should-be problem. Turned out that the hose going to the pump had pulled just a bit loose over the decades...I tightened it up (otherwise in good condition) at both ends and the water went away. Still don't quite know how it ended up THERE, but that's where it was. One thing you might want to check, it afflicted a friend's Maytag for some time: They really need to be very much level and on a solid floor. If they aren't, water filling the tub can be diverted over the edge (yes, I know that sounds like way out of level, but it truly doesn't take as much as one would think for just a bit to spray over the edge). Good luck and let us know how things go. |
