I will have my 4th HE5 dyer delivered tomorrow. The dryer door won't close properly. You have to push on the top of the door to get the top to latch then the door will pop open. It is very obvious when closing the door that is out of line. The bottom of the door hits and then shifts upward when closing. If you slam the door it will sometimes close normally. Has anyone heard of similar problems? Does anyone know a # to call to see if there is a problem with the dryers and what to do to correct it. They keep sending out new dryers.
