Thread Number: 12168
Heads Up! GE Electric Dryer in GA |
Post# 214626   6/6/2007 at 15:56 (6,167 days old) by launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 214633 , Reply# 1   6/6/2007 at 16:37 (6,167 days old) by roto204 (Tucson, AZ)   |   | |
Post# 214656 , Reply# 2   6/6/2007 at 19:58 (6,167 days old) by gyrafoam (Wytheville, VA)   |   | |
I always loved the idea of those for the huge opening and drum, but seems like someone (Gansky?) told me they didn't dry too good. |
Post# 214675 , Reply# 3   6/6/2007 at 20:36 (6,167 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Oh, Hunny puhlease! Don't get me started! Actually, they aren't the worst ever but do have some unattractive character flaws. This is/was originally a Hotpoint designed dryer, built in the Hotpoint factory, not in Louisville at GE. The overriding flaw of these machines is that they used the blower from a standard capacity GE dryer which wasn't enough air-flow through the drum to carry away the hot, moist air and lint fast enough which made a mess and lengthened drying time - especially with large loads in that 7 cu. ft. (?) drum. The load would heat up and moisture would begin to condense around the door opening and around the outside of the filter-grille inside the door. This moisture attracted lint, hair, etc. When the clothes were done, you had to clean the entire circumference of the door opening before removing the load or the lint would end up on the clothes that you had waited an extraordinary long time to finish drying. Adding to the aggravation was the extra large door that would push almost any laundry basket away from the machine or prevent the closing of the door unless it was moved first - especially annoying in a tight laundry space. The TOL models did have a very good moisture sensor and they were relatively quiet. I'd give it two stars out of five ;-) |
Post# 214730 , Reply# 4   6/6/2007 at 23:14 (6,167 days old) by appnut (TX)   |   | |
