Thread Number: 1292
Frigidaire Rotating Tub |
Post# 57272 , Reply# 1   2/15/2005 at 08:57 (7,008 days old) by Unimatic1140 (Minneapolis)   |   | |
Only the Unimatics give a 1/2 tub turn at the start of pulsation as it has to unwind its clutch spring to shift out of spin mode into agitation mode. The pause before the wash (there is no pause before rinse agitation) is due to the fact that there are two timers available for unimatic washers. The video shows the standard timer as in all of my Unimatics, the other timer is the Low water pressure timer, it uses that pause time to continue filling for another increment. |
Post# 57275 , Reply# 2   2/15/2005 at 09:10 (7,008 days old) by pulsator-power (connecticut)   |   | |
That's interesting, I never knew why. Why, after spinning, before the tub totally stops moving does the pulsator sometimes start moving up & down while rinse fill begins? Jerry |
Post# 57333 , Reply# 3   2/15/2005 at 20:07 (7,007 days old) by appnut (TX)   |   | |
Post# 57345 , Reply# 4   2/15/2005 at 20:54 (7,007 days old) by Unimatic1140 (Minneapolis)   |   | |
