Thread Number: 14517
Calling Maytag washer experts! |
Post# 247174 , Reply# 2   11/8/2007 at 13:32 (6,006 days old) by hoover1060 ()   |   | |
Yay for you Bobby, you posted your first pic!! |
Post# 247203 , Reply# 3   11/8/2007 at 16:09 (6,006 days old) by bobbyderegis (Boston)   |   | |
Thanks, John. Kind of figured. Does anyone need it? Bobby in Boston |
Post# 247257 , Reply# 4   11/8/2007 at 23:06 (6,006 days old) by sudsmaster (SF Bay Area, California)   |   | |
As I understand it, you don't have to compress the springs to change the damper pads. The process as I recall it as described to me: 1) Unplug washer (duh) 2) Remove front and top of washer - possibly the top just needs to be raised enough to let the tub go up a few inches. 3) Remove belts 4) Set main (biggest in the middle) pulley on a wood 4x4, so that it lifts the tub off the base support. See #6 5) At that point, the pads should be exposed and you should be able to remove the old ones and install the new ones. 6) I haven't done this but since the entire washer is balanced on a 4x4 block of wood, you might want to brace the washer at the edges/corners as well, so it doesn't fall off the 4x4 and slam the tub support onto the base support (and maybe on your fingers!). |
Post# 247280 , Reply# 5   11/9/2007 at 05:45 (6,005 days old) by kenmore58 (Rhode Island)   |   | |
