Thread Number: 15771
Wanted: pictures of HOH Maytag dryers |
Post# 264434   2/11/2008 at 08:43 (5,915 days old) by maytagwc401 ()   |   | |
Hey guys, I would like to have a few good pictures of the inside of Maytag's halo of heat dryers. If someone could post a few, it would really be appreciated. Thanks, Serge |
Post# 264440 , Reply# 1   2/11/2008 at 09:53 (5,915 days old) by bajaespuma (Connecticut)   |   | |
Post# 264441 , Reply# 2   2/11/2008 at 09:53 (5,915 days old) by bajaespuma (Connecticut)   |   | |
Post# 264442 , Reply# 3   2/11/2008 at 09:56 (5,915 days old) by bajaespuma (Connecticut)   |   | |
Post# 264443 , Reply# 4   2/11/2008 at 10:03 (5,915 days old) by bajaespuma (Connecticut)   |   | |
I'll take a picture of the inside with clean up and new light and filter when I can. BTW I love this dryer; fast, quiet and great timer controls. Even though the newer generation Maytag dryers were larger and more ergonomically designed, these things had the heart and soul of old Maytag perfection. Sort of like comparing the Brooklyn Bridge to the Verrazano.
Post# 264459 , Reply# 5   2/11/2008 at 12:20 (5,915 days old) by tuthill ()   |   | |
what is the maytag halo of heat? |
Post# 264468 , Reply# 6   2/11/2008 at 13:39 (5,915 days old) by qsd-dan (West)   |   | |
Post# 264479 , Reply# 7   2/11/2008 at 15:33 (5,915 days old) by charbee ()   |   | |
Here are the pics we posted when we got our DE-606: CLICK HERE TO GO TO charbee's LINK |
Post# 264499 , Reply# 8   2/11/2008 at 16:28 (5,915 days old) by maytagwc401 ()   |   | |
VERY NICE! Keep them coming! I love that machine! Thanks, serge |
Post# 264543 , Reply# 9   2/11/2008 at 23:55 (5,915 days old) by peteski50 (New York)   |   | |
Post# 264683 , Reply# 11   2/12/2008 at 18:01 (5,914 days old) by pturo (Syracuse, New York)   |   | |
This dryer took some work and rewiring but works perfectly now and very quiet and accurate! |
Post# 264684 , Reply# 12   2/12/2008 at 18:03 (5,914 days old) by pturo (Syracuse, New York)   |   | |
Pictures |
Post# 264685 , Reply# 13   2/12/2008 at 18:04 (5,914 days old) by pturo (Syracuse, New York)   |   | |
Control Panel |
Post# 264686 , Reply# 14   2/12/2008 at 18:06 (5,914 days old) by pturo (Syracuse, New York)   |   | |
Flame in front, got marshmallows? |
Post# 264688 , Reply# 15   2/12/2008 at 18:46 (5,914 days old) by toggleswitch (New York City, NY)   |   | |
Post# 264698 , Reply# 17   2/12/2008 at 19:50 (5,914 days old) by toggleswitch (New York City, NY)   |   | |
Post# 264699 , Reply# 18   2/12/2008 at 19:55 (5,914 days old) by johnb300m (Chicago)   |   | |
Post# 264710 , Reply# 20   2/12/2008 at 22:11 (5,914 days old) by neptunebob (Pittsburgh, PA)   |   | |
Post# 264712 , Reply# 21   2/12/2008 at 22:57 (5,914 days old) by pturo (Syracuse, New York)   |   | |
They are actually not that easy to service,the entire cabinet needs to be taken off,but they are really good at what they do. They should have had a front panel take off to service. |
Post# 1190077 , Reply# 22   9/16/2023 at 01:18 (220 days old) by Maytag85 (Sean A806)   |   | |
I think the reason why Maytag throttled the heat output to 18,000 btus was the 22,000 btus probably did a number on the large outer felt seal right by the air mixer assembly which slowed down the drying speed since the high limit thermostat was kicking the burner off since the incoming air was bypassing the burner cone. While 18,000 btus is on the lower side to begin with, definitely gentler on certain types of clothes. Even more gentle if the cycling thermostat is replaced with a L120-10 low heat thermostat.
Post# 1190081 , Reply# 23   9/16/2023 at 06:41 (219 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Used a lower 18,000 BTU burner as did some other poorly designed gas dryers.
I’m sure Maytag was being cautious because of the placement of the flame so close to and under the flammable seal and because of the general poor blower performance on halo of heat dryers. The belt tension was very light for the primary belt on these dryers so there is a good deal of Slipyj, especially with a heavy load on the primary belt at the motor, pulley and some of the blower pulley as well. The blower itself was not nearly as robust as the blower and Kenmore and whirlpool dryers either GE for that matter Of all the popular dryers the halo if he gas dryer was certainly the slowest one at trying to load of clothing. It was the only gas dryer I ever saw when consumer reports test that took longer than the electric version , The electric halo of heat dryers also were lower wattage that almost any other dryer it only 4800 W you had whirlpool in Kenmore dryers at 5600 W for example. Between the lower capacity and slower performance, you can see why Maytag dryers were not favorite for large families. Lots of laundry needed to be done on a weekly basis. One of our neighbors that had nine children had a Maytag halo if he gas dryer that thing ran all the time, but she still hung a lot of laundry on the line When we finally replaced it with a whirlpool gas dryer in the early 80s, she proclaimed that she never knew a dryer could be so fast and keep up with the washing machine. |
Post# 1190093 , Reply# 24   9/16/2023 at 10:45 (219 days old) by Maytag85 (Sean A806)   |   | |
Since I’ve used both gas and electric HOH dryers, the electric is indeed faster. But one nice thing I like about the gas HOH dryers is they are actually quite gentle on clothes when everything is tuned up properly, reason why they got a bad wrap for being slow is the pilot was left on and qsd-dan mentioned (can’t remember the thread) that every gas HOH he had come through had a weak high limit thermostat which was caused by the standing pilot weakening the bimetallic metal inside the high limit thermostat which would shut off the burner sooner than necessary. Had that happen once when I left the pilot on the Maytag DG306 but once I got into the habit of turning the pilot off when not being used, never had issues with that again. I want to start using that dryer again since I converted it into a DG407, but that probably won’t be until I figure out why it doesn’t turn on when plugged in, probably will look into it sometime next week.
Post# 1190103 , Reply# 25   9/16/2023 at 16:53 (219 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
The safety thermostat on the burner cone is in no way affected by the pilot light burning when the dryer is not in use.
It makes no difference in the speed of the dryer if the pilot light was on for days weeks or years before you dry a load of clothing that’s just ridiculous. It’s not a bad idea to turn the pilot off just to save the gas but it’s a lot of trouble to relight it each time you want to use the dryer and very few people ever did that. John |
