Thread Number: 16571
Whirlpool washer help uk |
Post# 274521 , Reply# 1   4/10/2008 at 09:29 (5,853 days old) by dyson2drums (United Kingdom)   |   | |
Post# 274534 , Reply# 2   4/10/2008 at 11:06 (5,853 days old) by mrboilwash (Munich,Germany)   |   | |
Could also be a faulty valve between the outer tub and the pump. You know, I mean one of those valves used to prevent detergent loss in the sump. But in this case it would at first drain all of the water and when the pump goes out some of it shoots back into the drum instead of sealing the outer tub. |
Post# 274549 , Reply# 3   4/10/2008 at 14:33 (5,853 days old) by hotpoint_42 ()   |   | |
ill check the machine when i go, i have spare inlet valves so ill take them with me when i go down. ur help is much appreciated thanks: Mrboilwash and dyson 2 drums. AmAr |
Post# 274654 , Reply# 4   4/11/2008 at 03:19 (5,853 days old) by irishmark (Ireland)   |   | |
hi id safely say theres a sock caught in the sump hose somewhere between the outer tub and drain pump,tilt the machine back and its easy to just remove the hose,when i was with whirlpool it was a very common fault,hope it helps |
