Thread Number: 21007
1951 Kenmore is the water supposed to be running allatha time? |
Post# 332535 , Reply# 1   2/27/2009 at 00:49 (5,531 days old) by tuthill ()   |   | |
Definately not supposed to be filling during wash, but I haven't the slightest clue wat's wrong with it. |
Post# 332580 , Reply# 2   2/27/2009 at 10:33 (5,530 days old) by unimatic1140 (Minneapolis)   |   | |
No, it appears that there is a small amount of voltage is getting though to the water valve. You should be able to tell if its hot or cold by the temp of the water. So check the voltage on the black wire to that particular water valve solenoid when the machine is agitating. Its probably leaking voltage through the timer or other loose connection.
