Thread Number: 22683
NEED HELP WITH THIS FRIGIDAIRE PUMP IMPELLER PLEASE |
Post# 355169 , Reply# 1   6/7/2009 at 00:20 (5,429 days old) by soberleaf ()   |   | |
on it |
Post# 355171 , Reply# 2   6/7/2009 at 00:21 (5,429 days old) by soberleaf ()   |   | |
removed from tub showing upper wash impeller. |
Post# 355172 , Reply# 3   6/7/2009 at 00:22 (5,429 days old) by soberleaf ()   |   | |
of the stainless wash impeller that sets on top of a black plastic hub. it is this hub that won't budge. |
Post# 355174 , Reply# 4   6/7/2009 at 00:24 (5,429 days old) by soberleaf ()   |   | |
the stainless impeller this is the hub that is stuck on motor shaft. it must come off to get to lower impeller and seal |
Post# 355175 , Reply# 5   6/7/2009 at 00:25 (5,429 days old) by soberleaf ()   |   | |
with top impeller |
Post# 355176 , Reply# 6   6/7/2009 at 00:26 (5,429 days old) by soberleaf ()   |   | |
stainless impeller |
Post# 355177 , Reply# 7   6/7/2009 at 00:29 (5,429 days old) by soberleaf ()   |   | |
using wire that i passed underneath this stuck hub. the wire broke as i increased the pushing down action of the center bolt |
Post# 355179 , Reply# 9   6/7/2009 at 00:34 (5,429 days old) by soberleaf ()   |   | |
would be appreciated. i know several guys here used to be service techs in the field, have talked to thtm before, am hoping some good info will come my way! thanks a heap pete |
Post# 355186 , Reply# 10   6/7/2009 at 01:30 (5,429 days old) by roto204 (Tucson, AZ)   |   | |
My copy of Doctrine says that the part you're pulling is the drain strainer and drain impeller plate. I'd scan it for you, but since HP produces such fine devices... Anyhow, here's the word of GM regarding assembly: The pump plate mounts to the sump of the wash tank. The seal assembly is press fit into the sump housing. The motor shaft which has two flat sides, extends through the seal assembly. The ceramic washer and rubber retainer press fits into the drain impeller as a sub-assembly which, in turn, slip fits onto the motor shaft. The drain impeller plate then is fastened to the sump housing. The drain strainer rests on top of the drain impeller plate with three non-symmetrical locators on the strainer matching notches provided in the plate. The recirculation impeller fits onto the motor shaft and is secured by a bolt and sealing washer. The bolt threads into the motor shaft. The recirculation housing rests on top of the entire pump assembly with the housing being fastened through the drain strainer, and into the sump housing. Only the recirculation impeller and the drain impeller with ceramic washer and rubber retainer rotate with the motor shaft. We need to figure out how to get your drain strainer assembly out (gently). It should just pull out...maybe take a very tiny jeweler's screwdriver and start prying gently at the edges around the perimeter? I see you already have the screw for the drain impeller plate out. Maybe some people more experienced than I have some good pointers for you. (If it were Greg, he'd hit it with his wrist, and it'd fall out beautifully, while I'd be there with tweezers and a Q-tip trying to tease it loose.) I hope this helps...be gentle trying to get at the drain impeller assembly! :-) Nate |
