Thread Number: 23918
Filter/Rim Flo Question |
Post# 372243   8/15/2009 at 01:52 (5,367 days old) by macboy91si (Frankfort, KY)   |   | |
Post# 372250 , Reply# 1   8/15/2009 at 03:12 (5,367 days old) by norfolksouthern ()   |   | |
First, check the feet and make sure they are firmly planted on the floor. I don't think the Hotpoint or GE Flo models have a balancing mechanism. They use a heavy brick instead! NorfolkSouthern |
Post# 372272 , Reply# 3   8/15/2009 at 07:11 (5,367 days old) by bajaespuma (Connecticut)   |   | |
While you're at it, find a carpenter's level and make sure the machine is level, using those same adjustable feet. Usually on later GE's and Hotpoints, the back pair of feet were "self-leveling" so only the front ones can be adjusted. If you live in an old wood-framed house, though, sometimes the floors of some rooms are just too "bouncy" for these machines and they're going to rock and roll and make noise whatever you do.
Post# 372309 , Reply# 4   8/15/2009 at 10:12 (5,367 days old) by macboy91si (Frankfort, KY)   |   | |
Is the tub supposed to wobble so far out of whack as well? The whole tub gyrates when it does this. It's a newer style Hotpoint, towards the later run of the Rim-Flo with the black consoles. It has the double-agitation handwash thing as well, seems to be a nice machine, but I'm not familiar with how these work. It has a large cement chunk in the bottom though. I'll try to mess with the legs and see if that helps. Can I open the top and see anything? If so, how do you open the top panel? -Tim |
Post# 372320 , Reply# 5   8/15/2009 at 10:51 (5,367 days old) by macboy91si (Frankfort, KY)   |   | |
I took a quick snap of the machine doing it's "thing". Figured out how to open the top (easy), may need a new top tub seal, but I'll see if leakage is an issue. There is a cable suspension along the front and right edges and looks like the majority of the "movement" is actually in the drive mechanism? It's a big ole tub that is fixed to the cabinet, and the inner-tub moves. It's weird. -Tim CLICK HERE TO GO TO macboy91si's LINK |
Post# 372386 , Reply# 6   8/15/2009 at 16:57 (5,367 days old) by yogitunes (New Jersey)   |   | |
