Thread Number: 24055
Filtramatic Dryer |
Post# 373992   8/23/2009 at 10:23 (5,358 days old) by frigidaireguy (Wiston-Salem, NC)   |   | |
Where would the serial number for a Frigidaire Filtrmatic be located ??? I'm trying to find what year my machine was made. 1952,1953, or 1954 ??? Thanks for your input. Bob |
Post# 374003 , Reply# 1   8/23/2009 at 11:44 (5,358 days old) by revvinkevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 374198 , Reply# 2   8/23/2009 at 20:50 (5,357 days old) by swestoyz (Cedar Falls, IA)   |   | |
If you pull the Filtrator cartridge out of the machine, the data plate is located on the top portion of the frame/cabinet, closest to the dryer door (between the door and the cartridge). I've always wondered how you can convert the serial number to year or month, similar to what you can do with a Maytag. Anyone here know if that is possible? The TR-60 came out in 1952, if you have a TR-60-2 it would be 1953 to 1954. While the TR-60's may be called Filtramatics, they'll always be a Filtrator to me ;-) Ben |
Post# 374260 , Reply# 3   8/24/2009 at 06:36 (5,357 days old) by frigidaireguy (Wiston-Salem, NC)   |   | |
Thanks Ben for the info. I am also having a thermostat problem with this dryer. The heating element never shuts off What would be the "fix" for this problem - Thanks |
Post# 374273 , Reply# 4   8/24/2009 at 08:55 (5,357 days old) by swestoyz (Cedar Falls, IA)   |   | |
I don't have repair documentation on me at the moment, but the high limit thermostat should open if it runs too hot (guessing around 170/180 ish). When it has been running for about 5-10 minutes, do you hear the thermostat click when you adjust the dial? Typically I run the Filtrator at Medium and adjust higher or lower depending on what is being dried. When it approaches the set temp you should be able to hear it click when you adjust the dial. Ben |
