Thread Number: 24807
PRIMING &PAINTING & FLAIRS..... OH MY!!! |
Post# 383358 , Reply# 2   10/6/2009 at 21:43 (5,312 days old) by soberleaf ()   |   | |
i am putting 4 coats of primer on it, probably major overkill but oh well.......... |
Post# 383360 , Reply# 3   10/6/2009 at 21:49 (5,312 days old) by soberleaf ()   |   | |
was primed. i usually don't prime that bi an area of the sump but this was origonally started last spring and i have learned some tips since then. |
Post# 383361 , Reply# 4   10/6/2009 at 21:51 (5,312 days old) by soberleaf ()   |   | |
in cleveland a few weeks ago needed a bit of sump attention so here it is after it's minor touch up. |
Post# 383362 , Reply# 5   10/6/2009 at 21:53 (5,312 days old) by soberleaf ()   |   | |
i had already primed and painted the underrside of the sump several weeks ago. hope to have this one back together by next week. |
Post# 383364 , Reply# 6   10/6/2009 at 21:55 (5,312 days old) by soberleaf ()   |   | |
on the custom imperial before i started on it |
Post# 383365 , Reply# 7   10/6/2009 at 21:59 (5,312 days old) by soberleaf ()   |   | |
cleaned and scrubbed and lint picked and outer surfaced primed |
Post# 383367 , Reply# 8   10/6/2009 at 22:01 (5,312 days old) by soberleaf ()   |   | |
just a few small rusted areas that will be an easy fix |
Post# 383369 , Reply# 9   10/6/2009 at 22:05 (5,312 days old) by soberleaf ()   |   | |
of the enamel finish was sprayed on the outer tub tonite. painting it royal blue. |
Post# 383370 , Reply# 10   10/6/2009 at 22:10 (5,312 days old) by soberleaf ()   |   | |
"tiger' the new kitten had to check it all out. here he is perched on top of my custom deluxe rollermatic watching the whole scene unfold in the living room. |
Post# 383372 , Reply# 12   10/6/2009 at 22:18 (5,312 days old) by soberleaf ()   |   | |
with all that glass and chrome! |
Post# 383376 , Reply# 15   10/6/2009 at 22:30 (5,312 days old) by soberleaf ()   |   | |
had mentioned possible bad wiring but after a pretty close inspection everything looks very good on this one! |
Post# 383378 , Reply# 16   10/6/2009 at 22:33 (5,312 days old) by soberleaf ()   |   | |
is also in good shape, it will be remounted on top of the ovens after i get the stove in place. |
Post# 383387 , Reply# 19   10/6/2009 at 22:56 (5,312 days old) by soberleaf ()   |   | |
here's the kdi-15 with it's first coat of shiny enamel on it's sump. the kdi-16 (that will serve as the other half of the stove base) i have not started painting yet. |
Post# 383389 , Reply# 20   10/6/2009 at 23:08 (5,312 days old) by norfolksouthern ()   |   | |
Which kinds of enamel are you using on these machines, Soberleaf? I really should consider refinishing the cabinet on my Roto-Rack. NorfolkSouthern |
Post# 383397 , Reply# 22   10/7/2009 at 00:00 (5,312 days old) by soberleaf ()   |   | |
for it's age and considering how rusted that motor shaft was. |
Post# 383402 , Reply# 25   10/7/2009 at 00:40 (5,312 days old) by aldspinboy (Philadelphia, Pa)   |   | |
Post# 383407 , Reply# 27   10/7/2009 at 01:37 (5,312 days old) by soberleaf ()   |   | |
has to be here! |
Post# 383412 , Reply# 28   10/7/2009 at 02:56 (5,312 days old) by whirlcool (Just North Of Houston, Texas)   |   | |
You are doing a fantastic job on your restorations. Are you using a rust inhibiting primer like POR-15 on the inside container of your washer? That before photo! Years of lint and gook! |
Post# 383439 , Reply# 33   10/7/2009 at 10:05 (5,311 days old) by soberleaf ()   |   | |
nicely and enjoys it's new home! |
Post# 383541 , Reply# 35   10/7/2009 at 21:15 (5,311 days old) by circlew (NE Cincinnati OH area)   |   | |
Wow Pete, looks like you've been busy. The washers are coming along nicely, and the Flair looks like it'll be really nice after some cleaning. Sent you another e-mail, hope you got it. Let me know if it didn't go thru, and I'll resend. |
