Thread Number: 25941
The Norge |
Post# 398496   12/9/2009 at 09:51 (5,244 days old) by bobbyderegis (Boston)   |   | |
Hi All! Now that my Christmas concert is over, I thought I would tackle the agitator on the Norge. The original one is broken at the top and is frozen to the shaft. Bobby in Boston |
Post# 398498 , Reply# 1   12/9/2009 at 09:52 (5,244 days old) by bobbyderegis (Boston)   |   | |
If you read the earlier thread, the replacement has lint crud stuck inside: |
Post# 398499 , Reply# 2   12/9/2009 at 09:53 (5,244 days old) by bobbyderegis (Boston)   |   | |
So now I need to remove the cracked agitator. Nothing made it budge, so since it was junk, I took the Dremel to it. |
Post# 398500 , Reply# 3   12/9/2009 at 09:55 (5,244 days old) by bobbyderegis (Boston)   |   | |
I worked at it for over an hour. I have never seen an agitator so frozen onto a shaft. I bet the crazy Youtube washer killer couldn't get this one off! |
Post# 398501 , Reply# 4   12/9/2009 at 09:57 (5,244 days old) by bobbyderegis (Boston)   |   | |
As I'm doing this, I hear someone knocking. I put down the Dremel and head for the front door. As I pass by the GE Filter-Flo, I realize the knock was an unbalanced beach towel that I had thrown in! |
Post# 398502 , Reply# 5   12/9/2009 at 09:59 (5,244 days old) by bobbyderegis (Boston)   |   | |
I finally get the agitator off. I could have cried. The shaft looks like something rescued from the wreck of the Titanic! |
Post# 398503 , Reply# 6   12/9/2009 at 10:00 (5,244 days old) by bobbyderegis (Boston)   |   | |
A close up: |
Post# 398514 , Reply# 8   12/9/2009 at 10:39 (5,244 days old) by unimatic1140 (Minneapolis)   |   | |
Post# 398531 , Reply# 9   12/9/2009 at 11:57 (5,244 days old) by mickeyd (Hamburg NY)   |   | |
Post# 398542 , Reply# 10   12/9/2009 at 12:42 (5,244 days old) by rp2813 (Sannazay)   |   | |
Post# 398578 , Reply# 11   12/9/2009 at 14:39 (5,244 days old) by norgeway (mocksville n c )   |   | |
I used one like this I got from lightedcontroldial in Virgina for over a year...until I got tired of my hubby complaining about how rough it was on his clothes.....I still think it is THE BEST washer ever made! |
Post# 399849 , Reply# 12   12/15/2009 at 09:54 (5,238 days old) by bobbyderegis (Boston)   |   | |
Larry at Modern has some parts. Does anyone know if there are four or six bolts under the wash basket? He doesn't have a diagram of this model, an LWA 2040 A00. Bobby in Boston |
Post# 399858 , Reply# 13   12/15/2009 at 11:08 (5,238 days old) by lotsosudz (Sacramento, CA)   |   | |
Post# 399876 , Reply# 15   12/15/2009 at 14:05 (5,238 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 399877 , Reply# 16   12/15/2009 at 14:06 (5,238 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 399888 , Reply# 17   12/15/2009 at 15:24 (5,238 days old) by bobbyderegis (Boston)   |   | |
Love the older, slanted consoles. How Whirlpoolesque! Since there are only three tub bolts, I assume the agitator shaft cover would have six bolts, evenly spaced around the three, no? Bobby in Boston |
Post# 399891 , Reply# 18   12/15/2009 at 16:05 (5,238 days old) by rp2813 (Sannazay)   |   | |
Post# 399897 , Reply# 19   12/15/2009 at 16:51 (5,238 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
From the Montgomery Ward Dept. 85 service manual for Norge-built washers: Center Post Assembly "The center post assembly is made up of the center post, a nylon bearing installed over the lower portion of the center post and a bearing installed in the upper portion of the center post. The center post assembly is secured to the upper spin tube hub by the 3 screws that secure the spin basket. A gasket is installed between the center post and the hub." I sounds like the shaft cover (center post) should be able to be removed with the 3 bolts when you remove the spin basket. |
Post# 400165 , Reply# 20   12/16/2009 at 18:54 (5,237 days old) by norgeway (mocksville n c )   |   | |
YOU WILL LOVE IT!!! |
Post# 400247 , Reply# 21   12/17/2009 at 06:52 (5,236 days old) by bobbyderegis (Boston)   |   | |
I'm trying my best Norgeway. I'm one step closer to an agitator post. Nothing beats a Norge! Bobby in Boston |
